Which Motherboard
grayp95
For a Athlon X2 4400, X1950 Pro
DFI Lanparty or Asus A8N-E
Can i still just use 1 card with a board that has 2x Pci-E x16 slots like the DFI?
Thanks
are you going to use it for what? max o/clocking,stock speeds.
with the dfi you must have specific ram and power supplies and be able to configure ram timings manually.the asus which im using is a great moderate o/clocking board and not so picky with power supplies and ram.
it all comes down to what you are going to do with your system.the dfi is the best board for high o/clocks but you must use certain parts to get a trouble free build.it also helps if you are a fairly competent builder,having some experience setting boards up.the asus is much more forgiving and will match dfi"s performance up to where it wont go any higher due to the bios settings not going as high as dfi's.both are excellent boards and perform well.i have only the best things to say about the asus a8n-e.im currently running an a64 3200 venice at 2600mhz with corsair xms 3200c2 ram 2/512 sticks.all this on stock voltages.i had the ultra d also but it was alot of trouble to keep tweaking it for a few more mhz.the asus board is referred to as a plug and play board and the dfi is not a plug and play board.if you go with dfi please read the forums on dfi street as to setup and reccomended parts .this will avoid many of the headache you will encounter with the dfi if you try and use low line parts with it....good luck
Either one should be fine. The A8N-E might be a tad easier to get up and running, but if you're into tweaking or overclocking, the DFI is the way to go.
You can use the DFI board with only 1 video card.
at stock speeds the the asus is a great board.what type of ram are you going to run and what p/supply? newegg has the a8n-e for 77.00 dollars or so.what a good deal that is.i paid 115.00 9 months ago.you'll be very pleased with you a8n-e as it has become my favorite board .its been a total pleasure to work with.i build systems for a living and this board is so stable its hard to believe.i run a business off it and its o/clocked too.from day 1 ive never had a crash or blue screen.it benches well too.good luck with your build and let us know how it turns out.somewhere along the line you'll have to replace the nf2 chipset fan so you may want to do it before you install it into the case.......
Thanks agian, here is the system that is being built.
Enermax Noisetaker 2 485 W 2x12v @ 22A
AMD Athlon 64 X2 4400+ Toledo 2.2GHz Socket 939 Processor
ASUS A8N-E Socket 939 NVIDIA nForce4 Ultra Motherboard
2g Corsair Dual Channel 512x4 Valueselect
Diamond Viper X1950 Pro 512 MB
dude,
just remember your ram will run at 333 and not 400 with all 4 dimms filled.its a memory controller issue with a64's .if you havent ordered yet you need to order 2/1 gig sticks.
ram will run at 333mhz and 2T timings....now if your ram is single sided sticks it may run at 400.if its double sided [chips on both sides of the ram pcb] them your done its 333.
there are some issues with running 4 dimms.they all have to be matched....same part #'s,same rev #'s and same chips on the ram.....micron,samsung,hynix for example.
it may not boot if everything isnt just right.2/1gig sticks are the way to go with a64's.
sell em and buy 1 gig sticks or run em and run slower ram.alot more issues with 4 dimms,just be aware..........and good luck...let us know how it turns out....
pm me and let me know,im curios
Ok, that sucks but ok. I already have 2x 512 (dual channel kit) of 3200 from my old setup that i was just going to add another dual channel kit too. I dont actually have the 2nd kit yet. So i guess ill just Stick with 1 gig for now and upgrade to 2x1g sticks in a few weeks. Thanks for the heads up.
Edit: Will i even see a performance boost running 4x512@333 over 2x512 @400? For gaming that is, games that use large textures and whatnot.
