Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I have been out of the hardware loop for a while, looking at purchasing a dual quad core computer, wondering which is better, AMD or Intel for Video/3D Rendering?
Intel is fastest I think from all benchmarks etc. but that is not taking into account any speed/price ratio. If just talking about raw speed Intel wins hands down.
if your software will support that hardware it would be a monster.
Look very carefully at the chipset features. A dual socket i7 family (or Xeon) would be the way to go for top of the line. Most of them are server class boards and support a limited number/class of CPU. For example you need an Intel CPU with 2 QPI links for dual socket. (I think, I am not up on it as well as I used to be).
But if money is no object and raw performance is the primary concern I am pretty certain Intel cannot be beat at the moment and near future.
