Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
They are both 3060's so it really comes down to your personal needs. The Gigabyte will probably perform better as it is a bigger card with more cooling area. But by that same token, the Zotac may be better if you are space constrained.
But if space isn't an issue then I'd say get the Gigabyte, but honestly, either should be fine.
