Nov 22, 2008 #1 S SD31P4ME Weaksauce Joined Sep 16, 2006 Messages 79 im looking at purchasing some memory. and i have narrowed it down to this 2. which one should i get. 1-ddr2 800mhz with 5-5-5-15 timming and Latency is 5 or 2-ddr2 667 with 4-4-4-12 timming and Latency is 4
Nov 22, 2008 #2 V Vinnard Gawd Joined Jul 7, 2008 Messages 682 What is your budget? You could probably get some ddr2 800mhz with a CL of 4
Nov 22, 2008 #4 Dangman Ninja Editor SuperMod Joined Dec 15, 2005 Messages 46,056 What CPU do you have? Are you planning to overclock?
Nov 22, 2008 #5 V vertigomhs [H]ard|Gawd Joined Aug 1, 2008 Messages 1,231 why not go with these: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231209 4gb of ddr2-800 at CL4, with only 1.9v, and its only $49 + FS. NOTE: make sure they fit,as they have the heat fins. also, g skill makes other cl4 kits but they are more expensive.
Nov 22, 2008 #6 S SD31P4ME Weaksauce Joined Sep 16, 2006 Messages 79 sorry vertigomhs my bad i need this memory for a laptop
Nov 22, 2008 #7 bigdogchris Fully [H] Joined Feb 19, 2008 Messages 19,120 If you don't plan on OCing, get the 667 (if it's cheaper). if you do plan on OCing, get the 800.
Nov 22, 2008 #8 S SD31P4ME Weaksauce Joined Sep 16, 2006 Messages 79 both cost the same. and i don't think i will be OC andytime soon. but since both memories cost the same i just wanted to know which one works best
