Hey, I have a HDR 40 base, but the cans are broken. Would this base be compatible with the HDR 100 series? kotlt1, what will you be using the headphones for? What kind of music do you listen to?
hello,
i prefer to listen soft pop, gothic rock
Hey, just got my RP-21's the other day and I love them! Thanks for the recommendation. Anyways I like them too much because now I can't stand my shure E2c's so I need something new for my portable build. Are the K81dj's + little dot micro a good combination for $80, or should I go for either the KSC75 or KSC35's? Any other opinions are always welcome too
I keep hearing about these RP-21's,maybe I should check them out.Like the looks on them if nothing else.
So you don't think the RP-21's are good for gaming? Is it worth the money to get some Koss SB's specifically for gaming over the equations? And 45's recommended over the 40's?
Just thought I should mention that I have received my AKG 81dj's today and I am very impressed. I find them perfectly comfortable, though my ears do get hot after some 30 mins of use. I'll post back once they've burnt-in.
lol cool
I will try for some Ultrasone 780s soon.
lol cool
When you do let me know how they sound, I been trying to get info on them. Because I found out about them on head-fi. and could be my perfect headphones. once I some how get 249 dollars.
RMCaudio.com has them for $200
I think I've read that the bass can kind of obscure the audio w/ the DT770's (haven't heard them personally though). If you want pinpoint positional then go for some AKG K501 or K701.
