WhiteFireDragon
- Jul 16, 2009
i'm looking for a set of headphones to get, but i'm a bit overwhelmed by the choices on newegg. here are some factors to consider:
1) price. i'm willing to spend up to $100 if it's really worth it. for example, if there's a decent pair that's $30, then there's one that's just a little better for $100, i'm not going to fork out over 3 times the cost just for very small differences.
2) comfort. almost every day, i will listen to 3-6 hours of recorded classroom lectures in one sitting. my ears would appreciate it if they wouldn't ache after a few hours.
3) purpose. they will be used for music (mostly mp3 and FLAC format files), very little gaming (only starcraft2), and listening to recorded lectures. mic would be nice, but not required. they will be plugged in to either onboard computer ports or my z5500 speaker pod.
here are some i've considered on newegg, or please suggest some other ones if it's better
SONIC HP-259
Rosewill RHM-556
RAZER Carcharias
Creative Fatal1ty
Logitech G35
steelseries 61001SS
SONIC HP-259
Rosewill RHM-556
RAZER Carcharias
Creative Fatal1ty
Logitech G35
steelseries 61001SS
