Which gpu for 3monitors is best?
kaper
hi, i would like to know which gpu is best to run 3 lcd`s something between 200-300$ with CUDA? i will use is for photoshop and gaming
my config is i5 2500k z68ap d3 8gb vengeance corsair curcial m4 128gb WD 320gb
thanks
thanks
Are you looking to game in NVsurround / Eyefinity or are you looking to game on one monitor while having the other two as extra desktop space?
I would say 1lcd for gaming 2extra desktop space
But it would be nice to try play on tree monitors ;)
I would recommend 1 7970 or a 7950. If you do want to game you can play BF3 at medium - high, and its just a great card for the price. Whereas if you choose Nvidia you will be stuck purchasing 2 cards unless you get that 580 that supports 3.
Highly dependent on the size of the displays as well. Assuming 1080P smallest?
You need 2 Nvidia cards for 3 monitors.. no one card for 3 monitors on that side.. Ati 7970 all the way since it can support 3 monitors or more prob off 1 card.
Lol 7950 its not in my price range tho
I have z68apd3 so wont work two,sli
On the other hand for two mid range Nvidia cards, at a lower price point, you get better performance. I'd buy the 7970 if I planned on buying another later. If you are never going to upgrade, I'd buy 2 Nvidia cards.
If you say CUDA, that is only supported by NVidia cards.
Galaxy 560 Ti MDT supports three monitors http://www.newegg.com/Product/Product.aspx?Item=N82E16814162082
But gaming across all three wil be limited to less demanding games. If you only game on one monitor, then there is no need to pay extra. Just use integrated graphics or the cheapest graphics card which you can find.
Reasonable gaming across three monitors on a single card starts around $350, e.g. http://www.newegg.com/Product/Product.aspx?Item=N82E16814130626 (dual-GPU card). Or buy two 460's for $130AR each. http://www.newegg.com/Product/Product.aspx?Item=N82E16814127646
The MDT cards do have some weird resolution limitation, it varies from 1080p down to 900p for some of the lower end cards.
Theres a 570 which should drop in price (hopefully) when the new nvidia cards come out (hopefully) next month. But is currently $379. This will do up to 4 1080p displays. Theres also a 560ti model, but I think that has a lower than 1080p screen limit.
A 7970 is waaay more than $300! :p
These are all great suggestions. With your budget, I would seriously look at the 560ti and forget NVSurround all together for right now. You can still use the other two monitors for extra desktop space and all the 2D work you could ever want.
For realistic performance in an Eyefinity/NVSurround solution you would need a larger budget for the video card.
Ok I cant put 2nvidia on my mobo?rite so I appreciate u telling me get nvidia but I cant then I wont play on all of 3 screen I can try and put lower resolution..but will be most likely on one screen...
Can I use vga on mobo and gt 9800? In same time so I could do 3 lcd
OP, all radeon 7xxx, 6xxx, and 5xxx series support 3 monitors and eyefinity off a single card.
You can get a radeon 6970/6950 or even a 6870/6850 to meet your budget.
I would say get any card and run the other two monitors off of the HD3000 built in for just desktop.
6950 will be able to do 3 monitors easily. It will play a ton of games at highsettings on eyefinity, some top tier games at medium, and some extremely tough to render games at low ( but you can always switch to one monitor if you have issues in which case youll be able to play on high again)
Won't have cuda.
Buy an Nvidia 590 or just buy a card to run 2 screens and a USB Video adaptor for the 3rd screens.
3 Screens is kind of a pain unless you use it for gaming - I think 2 is better for productivity.
odd number of screens is always better. this way one monitor is always dead center and reduces injury/ neck strain.
Won't have cuda.
Tough to knock the 6950. I have a 6950 (flashed to 6970) and it drives my 4960x1600 desktop fairly well (with an active DP to DVI adapter for one of the 1200x1600 screens). I only use the center 2560x1600 display for gaming, and it does OK for that at medium to high settings depending on the game. Could be better...quite a bit better honestly, but for 1080p a 6950 would be great.
