Bump: Adding a new question since I went with that corsair obsidian 550dcase mentioned below. It fits my needs perfectly and I was able to get it for $115 so not bad. Love the design too.
So now that I have the corsair obsidian 550D, it comes with the options of 120 mm or 140 mm fans in all the same spots. You can put 2 x 120 or 140 on the top and sides. A 120 or 140 on the bottom, and a 120 or 140 on the back for the main exhaust.
First question is...do you think it would make a huge difference in adding those fans vs keeping the panels on for noise reduction? And if adding the fans is a must for cooling move down to the next paragraph.
I'm pretty sure going with a 140 mm fan would greatly reduce noise while keeping up the air flow. My question is...which 140 mm fans should I get for the sides. I've already got 2 noctura ultra silent that I'd use on the top/bottom because they aren't sleeve bearings. I'm looking for a cheap, yet quiet solution for the sides.
So I've decided I don't actually need a performance upgrade based on input and my own thoughts. However, I want to sound proof (as much as possible) My Antec 900 mid tower case that sits on the floor under my desk.
The obvious noise makers are the fans. I already plan on lining the entire interior of the case with foam and my floor is carpet so that helps.
THE QUESTION: My case came with the following
1 x 120mm TriCool rear fan with 3-speed switch control
2 x 120mm TriCool blue LED front fans with 3-speed switch control to cool HDDs
200mm Fans
1 x 200mm top fan
Would upgrading these stock fans to something better be worth it for increased air flow and reduced noise? If so, what 120 mm & 200 mm fan would you recommend? I don't necessarily care about looks since it will be under a desk, out of the way. I'm all about optimization, aesthetics don't matter. And also, these fans in my case currently have a 3 position switch to control speed on each individual fan that can be adjusted. If I were to change to fans that didn't have something like that, would a fan controller be recommended? I'd prefer them to adjust automatically if possible so I'm also wondering if a software based fan controller would be best.
And currently my cooler master 212 seems to block me from putting on a side fan. Are there any fans out there that could fit? I've heard of people cutting off the top copper parts of their cooler master, but I'm worried that will effect it's cooling ability.
200mm Fans
1 x 200mm top fan
