Hi. I am one click away from buying 8GB ram and two new Gentle Typhoon 1850rpm fans.
I have two of those i the front of my Fractal Design Refine R2. I also have a VERY loud 1900rpm 120mm Scythe fan in the top which I am going to replace with the 1850.
I think I will add the other 1850 to the bottom, or do you think it is neccesary?
In the back I have a corsair fan that came with my Corsair H50 liquid cooler. Is it enough with 1 fan in the top and one in the back?
I am also going to buy a fan controller. Since I want to be able to close the door on my Refine R2 I want a flat one.
First one is the Scythe Kaze Master Flat.
Also Scythe Kaze Master II
I think both of these can turn the fans completely off, I think I have heard that it might not be good to do that with some fans. I'm not sure if that is true though.
Do you think I can set a minimum level or something like that?
Then there is also the NZXT SENTRY MIX, which, if I'm not mistaken, slow the fans dow to 40%.
That sounds like it could be a good idle speed to set the fans to. So it would be simple to just slow all of them down to 40% and not have to accidentally turn them off like I assume you can do with the other two.
I would really appreciate if anyone would help me with this!
Thank you in advance!
Edit: I think I'm going to replace the fan that came with H50 as well.
Just to make sure that it isn't wrong, should the pump be plugged into pwr_fan1? And the fane to CPU_FAN?
