Hey all, I've got some old drives in my desktop at home, which isn't a problem in and of itself; the problem is that I'm running out of disk space. So ... it may be time to get some new drives.
As it stands, I have five hard disks in my machine: one PATA 250GB Seagate, two SATA 320GB Seagates (RAID 1), and two SATA 500GB Seagates (RAID 1). I don't remember the model numbers off-hand, but I do know that I've had all of these disks for 3-5 years. I'm running both RAIDs on a Highpoint RocketRAID 2300 card.
Based on my experiences with single-drive systems, I promised myself that I would never store my data on a single hard disk again, hence the RAID 1s. I have no problems throwing the OS and apps on a single disk, though. To that end, I'm looking for 4 drives for data storage and 1 for OS/apps. Ideally, the 4 disks would be identical models and sizes, and the 1 disk would be bigger than 250GB. I don't want to spend a ton of money, so that combination of capacity and price rules out SSD for the boot drive; for the RAID(s) I'm looking for capacity over performance. 1TB drives are okay here, but I can go bigger if the price is right.
A little background ... I'm running two RAIDs in my office workstation (4x 750GB RAID 10, 2x 1TB RAID 1), but these are on the built-in Intel controller. The RAID 10 is made up of four Seagate 7200.12 drives, and the RAID 1 is a pair of WD Blacks with TLER enabled. The WD Blacks have been in a RAID 1, operating almost 24/7 for nearly a year now; the Seagate RAID 10 has been working fine since February. Recently we ordered three i7 workstations with four 1TB Samsung F3s in RAID 1 each, running on the Intel controllers built into their Gigabyte X58A-UD3R boards. These have been working well, but we got them about a month ago so I really don't know how they will hold up in the long run.
So, with the above in mind, which drives are currently the best for home RAID setups?
