Which cpu for this build?
Flashheart
I've been slowly upgrading my pc from the ground up. Currently I have...
Intel Celeron g1840 haswell socket 1150
Asus Z97-A
8gb ddr3 Kingston value ram 1600mhz
Gtx 1060 3gb
Evga 600b psu
Next step is a better cpu.
Which cpu would fit nicely with my current components?
£200 but if I can spend less and it would run on par with the other components then bonus.
A 4770/K or a 4790K for cheap would be great. If not, The highest clocked i5 you can get.
If you want to overclock, obviously you'd want a K model.
