Which CPU Cooler
cfetter79
will either of those even work with your socket 423 board? both of those only have attachments for socket A and socket 478. im not sure if the brackets from the 478 will work with the 423's
I would stay away from thoes blowers, i think most people do.
like kronchev said why not the Zalman 7000 AlCu?
but if your hearts set on one of thoes 2, get the thermaltake.
I was under the understanding that the P4's are socket 478's.. (and after furthur research, I've found I'm an idiot.). I looked at the P4 1.8 on newegg to check, and it's listed as a 478. But now on Intel's website, it's a 423.. .Shit!! Ordered the thermaltake listed above. Also, in the post above, what would make them "shitty"?
Thanks!
Excuse me, "crappy" not "shitty". It shows the Zalman being 478 also.. not 423.
Shit.
socket 423 was the older willamette p4's
socket 478 is the newer northwood and prescott p4's
I see.. Thank you for the info. It doesn't seem that there are many solutions (on newegg at least) for 423's. Again, it seems the Zalman 7000 is 478.
the socket doesnt matter at all, dont 423's use the same heatsink retention system as the 478s?
For about the same price you can get the Zalman CNPS7000-alcu which is a far better HSF and is very quiet. Stay away from the from the ones you mentioned like the plague.
Well kiddies.. the 478's don't fit the 423's... :confused: But, did put a 120mm exhaust fan, and just tried the Tt fan on my existing (shit) heatsink, and dropped temps to about 36 cpu/32 zone 1... and it got rid of the problem described above.
I'm done doing anything to this machine.
Next up.. A64!
Thanks for all the replies.
