which case
I dont have experience with these but I think the Stacker looks like it has better cooling and the looks are better overall.
i dont understand the craze behind the p180
It was designed from the ground up to be a very silent case. Rubber grommets for the hard drives, sound dampening material for the sides of the case, etc, And it looks pretty good IMO.
Anyway, before you go with a dual-card setup, do you actually have a 24" monitor in order for a dual-card setup to be worth it?
I cant speak for the stacker but my friend just picked up a p182. I helped him build it and it has some of the best cable management options ive ever seen. You can hide most of the cables behind the motherboard. It really looks nice once its done. His pc is near silent as well which is a huge plus. I do like the look of that stacker though.
