scharfshutze009
- May 22, 2010
I have an LG HL-DT-ST BD-RE GGW-H20L, which is My Blu-ray/HD-DVD writer combo drive. However, I'm not sure if it can write to HD-DVD though and if it can what software supports it. If I can't use this drive to burn to HD-DVD or find software that supports my OS or drive and/or both then the two 15 GB 1x speed HD-DVD disc's I bought are useless as I have not found anything I currently have that supports them. Please let me know all solutions for the following: Mac, Windows, and Linux. Do not recommend Image Burn if you can help it because it tries to hide asking if it can install spyware and bloatware. Also please try not to recommend CD Burner XP even though it doesn't have the problems that Image burn has because it's buggy sometimes.
