Which block?
Discussion in 'Water Cooling' started by Riccochet, Aug 3, 2018.
  1. Riccochet
    Riccochet Off Topic Award
    20,960
    Apr 11, 2007
  2. VanGoghComplex
    VanGoghComplex [H]ard|Gawd
    1,541
    Apr 5, 2016
    I have the Phanteks block for my ASUS 1080ti and really, really like it. The performance on the two will be within a degree of one another, so I'd say go with the one you like the aesthetics of.
    One other thing to note - I'm not sure if it'll be the same for the Gigabyte version, but on my ASUS Phanteks block I was able to reuse the stock ASUS backplate - a small nicety, considering what EK charges for one...
  3. Riccochet
    20,960
    Apr 11, 2007
    Not sure the Heatkiller or XSPC blocks will work with the non-reference PCB design of the Gigabyte Aorus card.
    I wouldn't mind getting the Gigabyte Waterforce block, but they don't sell it separate.
    Kyle_Bennett likes this.
  4. VanGoghComplex
    1,541
    Apr 5, 2016
    You would mind getting the Gigabyte Waterforce block. It can't be disassembled for cleaning without somehow removing the glued-on aluminum fascia that covers all the screws!
  5. Riccochet
    20,960
    Apr 11, 2007
    Good info! Off the list it goes!
    VanGoghComplex and Kyle_Bennett like this.
  6. WATERCOOL-Jakob
    WATERCOOL-Jakob Watercool Community Manager
    18
    Nov 2, 2017
    You can find all compatibility info for our blocks at http://gpu.watercool.de .
  7. Riccochet
    20,960
    Apr 11, 2007
    Thanks for the link! As I suspected, not compatible with my card.
