Which backplane?
The cabinet here is $1225.
Not horrible, but I'm still searching if the backplanes can be had separately like Supermicro or RAIDON can?
Not identical, but Supermicro's BPN-SAS2-216EL1 should be very similar. Not sure why you would want just the backplane though.
...Not sure why you would want just the backplane though.
Eight devices into the space of two 5 1/4 spaces has some appeal to me.
Edit: though I think in the long run it will be cheaper to go with this style: 4-in-1
That case more than likely uses a single large backplane instead of three smaller ones. If you looked on Supermicro's site, you would find all the info you need along with the part number for an 8 drive SAS expander backplane.
I would wager I would never find the info on Supermicros site for the original chassis I posted about.:D
No, but you would for the 8 bay Supermicro mobile rack that you posted.
Oh, I'm not questioning the SMI one or the RaidOn one I linked too. There seems to be info all over the web about those two.
