Which 8 Pin PCI-E Adaptor to use?
Ironman58
Like many, I bought a EVGA GTX 280 FTW - and discovered my power supply does not have an 8 pin pci-e connection. My power supply is a Rosewill - 850W unit and has 4, 6 pin pci-e connections. The power supply also came with a 6 pin pci-e to 8 pin pci-e adapter. However, my video card also came with an adaptor. However, it is a 2-6 pin pci-e to 8 pin pci-e adapter - as oppposed to the 1-6 to 8 pin adaptor that came with the power supply. Which would be the better adapter to use? I currently have the 1-6 pin to 8 pin adapter installed. However, I am having some issues playing Crysis. There are times when the game kicks back out to the menu. I guess I'm a little paranoid it's due to a power issue.
Any advice here on which adapter to use.
Tim
The two extra wires are only grounds, so it shouldn't actually make a difference which one you use. You could try the two 6-pin to 8-pin adapter like Danny suggested, but the grounds are all going to the same place so it probably won't help at all. It won't hurt to give it a shot anyway though.
