I'm going to order a 500GB hard drive, and was wondering what you recommend? I've pretty much narrowed it down to these:
WD RE2 5001ABYS
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136205
WD AAKS
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136073
Seagate 7200.11 ST3500320AS
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148288
or the ES.2 version for a few dollars more
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148294
I'm really leaning towards the the first one since the RE and RE2 series drives have a 5 year warranty from what I understand, and the RE2 is rated for 1.2 million hours. I know the Seagate ES.2 is very comparable, but it's slightly more expensive, and reviews seem to claim the seagate is louder
WD RE2 5001ABYS
WD AAKS
