which 4850?
Table
looking at buying a 4850 and im wondering which brand to get? I want it to be as quiet as possible but also reliable. Suggestions?
HIS brand usually are the quietest of the bunch due to their superior cooling setup.
yea, I also like the cooling fan on HIS, the hot air is exhausted from the case.
All the HIS cards on Newegg were pretty overpriced last I saw... That MSI with the heatpipe cooler seemed to do nearly as well (or better) as the Sapphire Toxic cards or some of the HIS cards on reviews across the net and it's much cheaper ($125 after MIR), FWIW... Probably doesn't push the hot exhaust out the back as well as the HIS card does tho (kinda fans it out in every direction).
I own a Sapphire and a Gigabyte 4850, of the two I prefer the Gigabyte, it oc'es way higher and idles in the upper 30's. I can't say much about the noise because I have several fans that drown the video cards out.
any 4850 + GFXChilla
http://legitreviews.com/article/740/1/
If you like silence, you will freak when you hear how quiet the GFXChilla is, and shocked at how cool your GPU stays....of course performance might diminish somewhat when you start Crossfire-X ing these cards with this cooler....
Just something to think about....for me it was worth it since I bought a used 4850 on here for $110 and got this cooler. Running 690MHZ core/1143MHZ memory....idles @28C in my antec 900. Full load, it doesn't even get to 40C overclocked. :)
