husker4life
- Aug 28, 2004
I've been looking at the LG W3000H, Samsung 305T, Dell 3007, HP LP3065. Which is best for gaming in your opinion?
Dell 3007 WFP-HC is currently the best for 30" gaming.
Like the OP, I've been on a bit of a quest to find a 30" LCD (one to replace my dying BenQ FP241VW), and it's come down to some of the ones the OP listed. The NEC, while nice, is a little out of my price range, and the only thing keeping me from jumping on the DoubleSight is the lack of HDCP support.
Other than that, I think the two I'm now torn between are the 3008WFP (since the input lag problem was fixed) and the 3007WFP-HC.
I got a refurb (RMA due to stuck pixels) and a new 3008 back in mid-January. Both were version 2. I don't believe Dell sells any v. 1 models now. A lot of problems were fixed with v. 2. My new 3008 doesn't have any of the backlight bleed or lag problems that plagued the first version.The input lag problem on the 3008 was fixed!? Please elaborate... Is that with the version 2 model? If so, how can you guarantee you receive a ver.2? I see dell still has some 3008's in their outlet.
Dell 3007wfp-hc, HP LP3065, and DS305W are the same. They use the same Q3 panel.
LG W3000H has got the latest Q5 panel so you should look into it.
Yup. The 3008WFP and W3000H use the same panel.The Dell 3008 is also a G5 panel.
The panel specs are identical for both LCDs. The first version of the 3008 had lots of problems that were corrected in v. 2.I thought the LG W3300H was a newer panel than the 3008 with less input lag, better response etc...
