I have a thermaltake core x9 case and I'm going to install a 120.3 rad in the front and I'm going to use a ek pump/res combo model 140 I believe along with only a single cpu block.
For the life of me I can't figure out where best to put the pump/res?? At the bottom, top or it don't matter?
Also I'm trying to install all of it so I can easily open a fillport at the top or res top and open a drain port and have all the coolant run out completely so I can easily drain and fill when needed.
So there's the tall question.. in order to do this shouldn't the ports on the rad be at the bottom with it vertical??
Normally I would run it with the ports at the top so air can't get trapped but I can't see how one could empty the rad without removing it to drain it.
Obviously a fillport at the highest point correct? The highest point would prob be the cpu block since the mb is horizontal. So some kind of T or Y connection before the block?
I've spent hours today starring at my rig trying to figure all this out before I hit Mc for parts and never left the house as it was too late! Haha.. time flies when your racking your brain over this puzzle.
