Åndhrimnir
- Nov 28, 2009
Hi all,
Planning a WC setup (my first) for sometime this winter - gonna get a 6970 and then watercool it and my current CPU (Phenom 9850).
I've been reading up on watercooling, but the thing I still feel fuzzy on is draining the loop for maintenance/case moving/etc. Unplugging tubes with liquid in them while they're inside my case sounds scary.
I've read up on quick disconnect fittings and they sound like a great idea. Trouble is, IDK where they'd go in my loop. I was thinking maybe one right between the pump and whatever is after it in the loop? So that I'd disconnect the pump from the next guy with no leak, then (over a bucket) unplug the connector from the tubing and then turn on the pump. Would that drain the loop into the bucket?
Or am I completely misunderstanding how draining a loop works?
Thanks for any help.
