Where to buy Cat6 cable (1000ft) ?
Discussion in 'Networking & Security' started by CorpX, Nov 1, 2009.
  1. CorpX
    CorpX Limp Gawd
    285
    Mar 1, 2005
    I was going to wire the house to add ports in each room, so what's a good place to buy 1000ft of cat6? I see some on monoprice and I see some on ebay for less, but I'm not sure which one suits me best. Any ideas?
    Thanks!
  2. alext5
    alext5 Limp Gawd
    169
    Feb 19, 2004
    Did you know that even 10g ethernet can run on Cat5e cable for short distances ?
    I just wired my house in cat 6 and when I was told that Cat5e can do 10g I wouldn't have paid twice as much for cat6.
    I bought it from a local distributor in Montreal but if I couldn't get it from cablek, I would have ordered it from Monoprice since I never had a bad experience with them.
  3. CorpX
    CorpX Limp Gawd
    285
    Mar 1, 2005
    Yes, I realize that cat5e is quite capable, but the switch will be about 100ft from the farthest access point, so I thought I might as well go with cat6.
  4. criccio
    criccio Fully Equipped
    11,968
    Mar 26, 2008
    100ft is nothing... Cat5e is MORE then capable.
  5. alext5
    alext5 Limp Gawd
    169
    Feb 19, 2004
    Obtained from wikipedia.org
  6. EvilAlchemist
    EvilAlchemist 2[H]4U
    2,747
    Jan 11, 2008
    I just got done building my house and ran Cat 6 to each room.
    I would highly recommend cablesupply.com
    http://www.cablesupply.com/ProductD...1000ft Category 6 Solid Bulk Cable PVC Jacket
    They were about $10 higher on price but very cheap on shipping.
    I purchased all my cables and patch panels there.
    There customer service is stellar and i was very happy with the service I got from this company.
  7. terrybogard21
    terrybogard21 Gawd
    644
    Jun 11, 2008
    Jesus & here I was thinking my 300ft. was way too long.
