Where does this piece go?
barefootbilly
And does it have anything to do as to why my frony USB ports stopped working? :confused: :(
I was rewiring stuff and that fell out, just not sure where from. :mad:
That is in fact a system speaker. That would have no effect on youre USB, but perhaps you rewired your USB header to the wrong pins. (or maybe 1 or 2 of them came disconected)
correct you are, the usb's were wired backwards, which I think may have fried my thumb drive. :(
anywho, how can i find out where it goes? a7n8x-e
That is the voltage regulator that keeps your motherboard from frying small USB devices such as thumb drives.
JK! LOL Yes, it is the little speaker, the manual should tell you exactly what pins it goes on.
Also check your case documentation to see what the pins are for the front USB's. If they are labeled differently, sometimes you have to make an "educated guess."
