price I was quoted is over $500 but under $600Moloch said:Uh.. unless you're getting for retail price(500?) then you shouldn't even consider it.
Pci-express= pwnage- an X800XL, when it comes out in few weeks, performs almost as good as the regular old XT, for 300..
Its pci-express only.CRXican said:price I was quoted is over $500 but under $600
X800XL you say? Sounds like I need to do some reading.
Elledan said:It's more likely that WTX will come back to life and replace every single ATX system out there than that BTX will ever have a marketshare of over 10%. BTX is dead. No amount of hype will bring it back to life.
Moloch said:Its pci-express only.
Nvidia hardly has any pci-express cards(high end) and ati isn't doin agp cards anymore![]()
I just sold my 6800GT, should have just held onto that a while longer, couldn't stand that loud fan though (I have a shuttle, single slot cooling only).Moloch said:Its pci-express only.
Sir-Fragalot said:Since the BTX standard cases haven't started shipping yet and no BTX motherboards will be available until sometime early next year, you're dead wrong. BTX is a new standard. It's not dead as it hasn't even started shipping yet. The only BTX case you can get now is the CoolerMaster Stacker case that's convertible between ATX and BTX.
Just what is the basis for your statement?
BTX has a terrible cooling system focusing on the cpu and nothing else. Since the new intel cpus run so hot this is great for them, However what about the rest of the components? The only btx form factor that shows promise is m-btx / pico. Besides having all of the oems redesign all of thier cases for btx seems like a pain in the ass.
Badger_sly said:For 2+ years AGP will be an easy option to find. 2.5 - 3 years from now, AGP will become slightly more difficult to find. In 3.5 - 4 years AGP will become real legacy hardware, similar to what happened to ISA.
The reason AGP won't die off overnight is that there is hardley any advantage to going PCI-E, and, the average computer owners (who are the real majority, not us tech-heads) don't buy whole new systems more often than 3-5 years. Basically, AGP will be weaned out as the majority of consumers upgrade their computers over the years.
I(illa Bee said:hardly and advantage in "APG vs. PCIx 16"..... how about "AGP vrs SLI"....
I belive the onyl reason any of us gammers want PCIx16 is for SLI...i dont thing any of us care about a singal PCIx16 videocard soultion
GlobalFear said:BTX has a terrible cooling system focusing on the cpu and nothing else. Since the new intel cpus run so hot this is great for them, However what about the rest of the components? The only btx form factor that shows promise is m-btx / pico. Besides having all of the oems redesign all of thier cases for btx seems like a pain in the ass.
What "some" manufacturers want, and what will really happen, will be two different things for the most part.Sir-Fragalot said:........Manufacturers want to make the transistion for reasons I stated above. We can already see that happening. ...........
Badger_sly said:What "some" manufacturers want, and what will really happen, will be two different things for the most part.
And, what is happening with PCI-E and SLI coming out is minuscule in the whole market. Because you or anyone else in this forum has or has ordered a PCI-E video card, and has or wants SLI, doesn't make AGP die any faster. It's understandable that because you spent money on the new technology, you'd want it to become more mainstream quickly, but that doesn't mean it's going to happen.
rcolbert said:Are there any chipsets forthcoming that support AGP? I'm thinking all the new chipsets on the roadmap are PCI-E only. I could be wrong. I think that will have more to do with it than anything else. If motherboard design moving forward either is based on existing chipsets to support AGP or new chipsets to support PCI-E, then take inventory now, 'cause there won't be any new AGP motherboards after the current chipsets have all been played out.
I strongly disagree with this statement. The chipset (NB and SB), voltage regulators (those things can get very, very hot) and other components like RAM require a lot of cooling.Sir-Fragalot said:Except for the video card, the other components don't need that much cooling.
Completely false. What happens is that all of the air, freshly heated by the CPU's heat, is blown over the rest of the components inside the case.With the CPU being cooled so much better, ambient case temperatures will drop significantly.
The only good part about the BTX spec, to be honest.[..] Heat rises and the video card is now opposed component side up.
No, it won't, because the videocard is being scorched by the 100+ Watt hairdryer at the front of the case (Prescott CPU + thermal module).With proper exhaust fans I think video card cooling will improve also.
This thermal image of a desktop BTX system I've got shows that BTX has the lousiest cooling solution ever devised. I expect lots of premature deaths of components inside BTX systems, as well as many unstable systems.BTX doesn't get rid of your case fans. I think the rest of the system cooling will be about the same.
BTX is unsuitable for dual CPU (NUMA) designs, like the Opteron, so that's at least one market where BTX will never become a success.[..]
AMD won't be making the change anytime soon to BTX if ever. If anything hurts the BTX standard, that will. But I think AMD will change over eventually.
Elledan said:I strongly disagree with this statement. The chipset (NB and SB), voltage regulators (those things can get very, very hot) and other components like RAM require a lot of cooling.
BTX is the complete opposite of ATX in this regard: with BTX the CPU is cooled first, then the rest of the components. With ATX the CPU is right next to the exhaust, allowing its heat to be exhausted immediately (ducts!).
As you might know, the warmer air gets, the less heat it can absorb. In order to remove as much heat from a system as possible it's therefore most efficient to move the air over the coolest components first, to end with the warmest components. This is where ATX gets it right and BTX totally wrong.
This is a very salient point. Will there be any new AGP cards made?Sir-Fragalot said:Well ATi isn't making the X850 series in AGP. The X700 series is PCI-E only. Intel no longer supports AGP in any of it's new chipsets. Nforce 4 is PCI-E only.
I think you're right. I own a Socket A Shuttle right now. I am looking at the SN95G5 Shuttle that was recently released. It is Socket 939 (the latest mobo/processor) but they chose to leave AGP video which confuses me a bit. I like my Shuttle and am leaning towards sticking with one. A new processor is all I should need (as long as my ram is compatible) and I'm good to go. If I consider PCI-E it's a whole new level of price vs. performance.uclajd said:This is a very salient point. Will there be any new AGP cards made?
I'd guess yes, but not immediately. Look what some mobo makers have done to incorporate the 865/876 chipset with 775. I doubt Intel had that in mind.
The point being is that there are millions of people with AGP boards full of RAM and a processor, and many of them don't want (or can't afford) to have to replace their entire system just to upgrade a video card. So there will be a market for AGP cards for the foreseeable future.
CRXican said:So I guess the moral of the story for me is:
Keep the 9800 PRO AIW, forget the 6800GT AGP and X800XT PE AGP and save up for a fancy PCI-E mobo (or Shuttle). I guess that makes the most sense.
With BTX, the expansion cards will be sitting in what basically amounts to a dead air pocket. The air coming from the thermal module will be exhausted by one or more exhaust fans at the back, meanwhile warming up the air around the expansion cards.Sir-Fragalot said:In the BTX case I saw, the video card didn't sit behind the processor. So as the heat is exhausted through the case it won't hit the video card. It will hit the motherboard, but I don't think it will be any worse than it is now. Since air flow through a system isn't very good in relation to motherboard cooling right now anyway.
At 80-100 Watt for the CPU? Aside from the GPU, this is more heat than produced by the rest of the components together.Right now I am looking at the BTX layout. I see that in all likely hood the air that comes off the CPU thermal solution will pass over the North and Southbridge chips and out the back of the case. The way I see it, the air that moves over it won't be as hot as you might think.
Which would mean more, and bigger fans. I thought we were trying to improve on ATX, which could do with only a couple of fans at most?And if evacuated from the case fast enough it shouldn't be a problem.
Again, that's the part of BTX which I actually like.Periphrial card cooling looks like alot of the heat that rises from the video card will exit the case where the CPU exhaust does.
Are we talking about the same Intel which recently cancelled the P4 line and the LCoS project? I still maintain that the BTX formfactor was created to compensate for the obscene power usage of the Prescott core.I see what your saying and I disagree with you. For one additional reason. The engineers at Intel that are designing the BTX form factor, are smarter than either of is. They got the job designing this crap and we didn't. Sometimes because of cost considerations and space considerations you have to give and take with the design and decide where your priorities lie. I think that although BTX will have some disadvantages, overall I think it will be an improvement.
(Baby-)AT and all other formfactors before ATX lacked certain features which ATX introduced. BTX on the other hand doesn't offer any significant features over ATX's.We aren't going to agree here and that's fine. If it's bad I think the OEM's would have cought on by now and said no way are we going to adopt this. But they haven't. So like it or not it's comming and it might now last, but everyone said the same thing about ATX too. For different reasons of course.
Hence one of BTX's failings compared to ATX. ATX is simply more versatile than BTX.I do agree that BTX won't work very well if at all for SMP systems. Unless they have a EBTX or something that creates the same basic form factor, but with a second CPU cooling solution. This of course would make for a very large case though.
Elledan said:With BTX, the expansion cards will be sitting in what basically amounts to a dead air pocket. The air coming from the thermal module will be exhausted by one or more exhaust fans at the back, meanwhile warming up the air around the expansion cards.
In other words, BTX makes the airflow through the case completely ineffective in cooling anything but the CPU.
Methinks their priorities lie with covering up the blunder which is the Netburst architecture.
arentol said:Let me make a quick list of typical expansion slots that give a flying fark about heat....
1.) Videocard.
2.)..... Hrrm.. there is no second item. Okay, all done with list.
Actually BTX cools the videocard far better than ATX (since it blows an immense amount of air directly across the hottest part of the video card), and it also cools the RAM (In part because of the positioning of the Powersupply fan), the Northbridge, and the South Bridge far better than ATX does.
Elledan said:At 80-100 Watt for the CPU? Aside from the GPU, this is more heat than produced by the rest of the components together.
arentol said:If their is a large amount of air passing quickly over a large heatsink then the air coming off the heatsink won't actually be heated all that much (try checking how cool air coming directly off your current HSF system feels).
Also the BTX specification causes a good bit of air to flow directly under the motherboard (and increases the space for that air flow), which should help lower overall system temps.
Soundcards don't like heat much, either. Nor do RAID cards (real ones, with onboard processor and RAM).arentol said:Let me make a quick list of typical expansion slots that give a flying fark about heat....
1.) Videocard.
With ATX, air flows from the front, over the RAM, HSF, voltage regulators to exhaust. With BTX, air flows from the thermal module, over the NB, over the RAM, to the exhaust. Conclusion, the air flowing over the RAM modules will be a lot warmer with BTX.Actually BTX cools the videocard far better than ATX (since it blows an immense amount of air directly across the hottest part of the video card), and it also cools the RAM
You absolutely do not want air from the HSF to pass over the NB, as the HSF is warmer than the NB's HS, thus you're not cooling the NB properly.(In part because of the positioning of the Powersupply fan), the Northbridge, and the South Bridge far better than ATX does.
So, we're back to the 'big fans, lots of airflow' solution which BTX tried to avoid, right?At 80-100 Watt for the CPU? Aside from the GPU, this is more heat than produced by the rest of the components together.
That's like saying that the patient died during surgery, but at least you managed to take out his appendix.Also the BTX specification causes a good bit of air to flow directly under the motherboard (and increases the space for that air flow), which should help lower overall system temps.
The problem is that you're not thinking like an engineerSir-Fragalot said:You may or may not be right on any or all of your points. I won't argue the points anymore. I would be willing to bet that it will work better than you think it will.
How, exactly? Cooling isn't better, positioning of components like HDDs is poor at best and a lot of space inside the case is wasted.I completeley agree with you. I sit there and look at the BTX layout and can see how it should work better than ATX.
Which side the mainboard is mounted to is no intrinsic feature of a formfactor. It's been done with ATX as well (Lian-Li's V1000, etc.).The biggest thing I don't like about the new form factor is the case opening on the wrong side. Like a damn Macintosh. That will take a LONG time to get used to.
Thanks for the propaganda. You really think Intel would offer a 'fair and balanced' overview of the BTX format? They're trying to sell something here.Sir-Fragalot said:I'll let the people who designed the thing explain it. I agree with what they are saying.
http://www.intel.com/update/contents/dt10031.htm
The ATX spec doesn't define anything regarding airflow. At most it recommends that the PSU is used for exhaust. Implementing a layout which allows for good airflow characteristics is the duty of the case manufacturer/OEM. This is by no means rocket science.ATX does a poor job bringing air in. The air it brings in is blocked by the drive cages and cables for them.
Mainboard manufacturers are free to use the space within Area A (refer to ATX spec sheet rev.2.1, page 17) as they please (except for the back I/O section). Many manufacturers often put the RAM slots in a vertical fashion, allowing the RAM to be cooled through convection.The ram blocks air from reaching the CPU or motherboard components. When the air hits the ram (as it is usually opposed horizontaly) it hits the one chip and very little air will get around that first chip.
There's more to cooling with air than just pushing loads of air through a system. In other words, it's not how much you've got, but how you use it. By avoiding turbulence where necessary, as well as dead air pockets, you only have to push enough air through a system to keep its components below a certain temperature.Not to mention a standard 80mm fan doesn't get much air over 12 inches in distance with only 32CFM's being pushed. It wouldn't reach the CPU or the bulk of the mainboard components anyway.
What about just flipping the ATX mainboard?Then as you've already agreed, the video card is faced down which allows all the escaping heat to bake the card. Since the video card runs as hot or hotter than the CPU, we can see that this part of the case design needs to change. Easiest way to do that is mount the system backwards so that the card faces up. BTX does this.
No it doesn't. Anyone who has studied this subject knows that the ability of air to 'absorb' heat doesn't decrease in a linear fashion. This is why in order to remove the greatest amount of energy (heat) from a system, it's crucial that the air is led over the components in order of temperature, with the coolest parts first. Because BTX reverses this order, it's less efficient at cooling the system than ATX.Air intake through the front of the case will go where it's needed the most. Right to the CPU directly. This makes sense.
True.Air comming off that heatsink will not be 100 degrees. Right now if I go home and touch my Prescott LGA775 heatsink, its warm, but not too hot to touch. The air comming off of it won't be 100 degrees. With greater CFM's of air comming through and hitting a larger heatsink. It will do nothing but drive the temperature down.
Because the videocard's MOSFETs only have to deal with a couple of voltages at most, at lower tolerances than the mainboard's MOSFETs, which not only have to supply a large array of different voltages, to not just onboard components, but also to expansion cards, fans and many other kinds of peripherals (USB devices, for example). Not to mention that the mainboard's MOSFETs have to deal with far more current, and thus heat up far more quickly.If the video card mosfetts can handle the heat of being placed in an area where the heat can not escape, and some video card GPU's get hotter than Prescott, why wouldn't the motherboard be able to handle as much?
You may believe this, but do you have any evidence to support this claim?I believe that mainboard components will be cooled better by the new system. The air comming off the cooler heatsink and from the intake fans will suffice.
You already mentioned this.The memory doesn't get cooled at all right now as most if not all the air is blocked by a drive cage. The way ram sits as I mentioned before, keeps all but the first chip completely blocked from air in most systems. This is pretty useless.
Please refrain from repeating unfounded statements.Ram on BTX is mounted vertcally. Therefore if air flow is directed there, it will go across the memory modules. This has potential in keeping overall system temperatures and memory temps down. Since ram isn't being cooled worth a crap now, it's nothing but an improvement here. Even if it wasn't, its not any worse. Also the ram won't block any airflow either.
Hence new, innovative videocard cooling designs like the one I mentioned earlier.Video card cooling will increase noticably. Realize that with hard drives in front of them in virtually every ATX case made in the last 7 years or more, virtually no air actually reaches the video card at all.
Actually, the first PCIe slot is located pretty much right behind the thermal module. Just look at the BTX layout.Secondly on the video card, it doesn't sit behind the CPU. Therefore the CPU won't be baking it.
Three words: dead air pocket. Not that it's much better than with ATX, but I doubt that any formfactor will solve this issue as long as expansion cards are kept horizontally on a level plane.Where does a second video card go? Well right below the other one. AWAY from the CPU. That's a good thing. The video card faces up and hot air rises.
You want to say that BTX is like the PowerMac G5 layout? You might want to take a closer look. Aside from the fact that Intel has made a poor attempt at introducing 'thermal zones' like the PowerMac G5 has, most similarities are superficial. Where are the thermal sensors, for example? What about dual CPU, dual RAM slots? BTX allows for none of those, or the spec is very quiet about it.[..]
Finally the G5 has been out for over a year. It has many design similarities to BTX and the G5 chip gets nearly as hot as Prescott. Hence why they chose to employ water cooling for dual 2.5GHz models. These systems are quite. Even the air cooled ones and have 6800Ultra's in them and many of the other technologies present in modern PC's.
If it works for Apple, why not Intel?
Jasonx82 said:Lol yeah, when i go to fix peoples computer i always wonder why they use that connecter to connect it to the PS/2 port maybe they think its faster cuz it was made for a mouse? heheh![]()
Elledan said:Thanks for the propaganda. You really think Intel would offer a 'fair and balanced' overview of the BTX format? They're trying to sell something here.
Look at this quote for example: " BTX is also optimized for the newest desktop technologies, including PCI Express and Serial ATA.". Heh.
Elledan said:The ATX spec doesn't define anything regarding airflow. At most it recommends that the PSU is used for exhaust. Implementing a layout which allows for good airflow characteristics is the duty of the case manufacturer/OEM. This is by no means rocket science.
Elledan said:Mainboard manufacturers are free to use the space within Area A (refer to ATX spec sheet rev.2.1, page 17) as they please (except for the back I/O section). Many manufacturers often put the RAM slots in a vertical fashion, allowing the RAM to be cooled through convection.
Most HSFs put the fan at the top of the heatsink. The RAM does not hinder the airflow in this configuration. You also may have noticed that most cases have over 10 cm of empty space above the RAM slots.
Elledan said:There's more to cooling with air than just pushing loads of air through a system. In other words, it's not how much you've got, but how you use it. By avoiding turbulence where necessary, as well as dead air pockets, you only have to push enough air through a system to keep its components below a certain temperature.
You'd be surprised to see how much a simple duct can improve cooling performance.
Elledan said:What about just flipping the ATX mainboard?
Elledan said:Also, there are already cooling solutions for videocards which exhaust the air outside the case. This is similar to the ducting solution for a CPU. This way the heat from the GPU(s) and CPU is directly exhausted without warming up the air inside the case by a significant amount.
Elledan said:No it doesn't. Anyone who has studied this subject knows that the ability of air to 'absorb' heat doesn't decrease in a linear fashion. This is why in order to remove the greatest amount of energy (heat) from a system, it's crucial that the air is led over the components in order of temperature, with the coolest parts first. Because BTX reverses this order, it's less efficient at cooling the system than ATX.
Elledan said:Because the videocard's MOSFETs only have to deal with a couple of voltages at most, at lower tolerances than the mainboard's MOSFETs, which not only have to supply a large array of different voltages, to not just onboard components, but also to expansion cards, fans and many other kinds of peripherals (USB devices, for example). Not to mention that the mainboard's MOSFETs have to deal with far more current, and thus heat up far more quickly.
Elledan said:You want to say, for example, that this thermal image of a BTX desktop system I'm looking at right now (look at those pretty red colours trailing behind the thermal module) is incorrect or false?
Elledan said:Actually, the first PCIe slot is located pretty much right behind the thermal module. Just look at the BTX layout.
Elledan said:Three words: dead air pocket. Not that it's much better than with ATX, but I doubt that any formfactor will solve this issue as long as expansion cards are kept horizontally on a level plane.
Elledan said:You want to say that BTX is like the PowerMac G5 layout? You might want to take a closer look. Aside from the fact that Intel has made a poor attempt at introducing 'thermal zones' like the PowerMac G5 has, most similarities are superficial. Where are the thermal sensors, for example? What about dual CPU, dual RAM slots? BTX allows for none of those, or the spec is very quiet about it.
Which, as I pointed out, is a failure of the case manufacturer/OEM, not of the ATX formfactor.Sir-Fragalot said:I was speaking of air flow through the front of the case and the way typical ATX cases bring air into the machine. They do a poor job of it.
Like the V1000 I mentioned in an earlier post?I thought of that too. It would work and I believe theres a Lian-Li case that does this.
With the Prescott running at temperatures well over 60 C during load with the stock HSF, Intel probably thought that the 'shotgun'-approach would work best to 'fix' this cooling issue. Until they decided to cancel further developments on the P4 core, that is.I see what your saying here. I think Intel banks on the components on the motherboard will survive and function well enough despite this. BTX simply does a better job of CPU cooling. Which is the main thing they are after.
So far. Soundcards, TV-cards, video-processing cards, RAID cards... they're all gaining new features, which require more, bigger and faster ICs and thus end up using more and more energy, losing much of if as heat. We don't even know how these and other cards will evolve, and which types of expansion cards will be introduced in 5-10 years time.I agree. And that continues to be a problem. But with the exception of a few select types of cards, few expansion cards aside from video get hot enough to need any kind of cooling.
The PowerMac G5 is more than its mainboard. Every single part has been designed to work together with the rest of the system. That's why you can't just refer to the PowerMac G5's mainboard (sorry, logic boardThere are similarities here. Aside from the CPU. The thermal zoning is different, while the basic theory remains similar.
The G5 may do it better. We'll have to see.
