AGP cards will vanish faster than PCI videocards (which are still being produced) for the simple reason that after the introduction of AGP, PCI was still an option on any mainboard with AGP, whereas with the introduction of PCIe, AGP is completely being replaced.Blauman said:look how long it took PCI video cards to dwindle. I mean you can still find them but you have to look around. I say 2 to 3 years is a preatty good assumption.
big time WORD to that... nothing pisses me off more than seeing a usb mouse plugged into a ps2 port through that stupid connector when they have open USB portsacascianelli said:there are other things id like to see 'vanish' before agp, like ps2, serial, parralel
Rogue4mula said:big time WORD to that... nothing pisses me off more than seeing a usb mouse plugged into a ps2 port through that stupid connector when they have open USB ports
inotocracy said:...what the hell is wrong with using a ps2 keyboard? I dont see any advantage of using up a usb slot for a keyboard when its pretty pointless to use anything but the ps2 for keyboard. Mouse is a different story since we need that added bandwidth for a high refresh... but a keyboard? Unless you type at 500wpm I dont see the need for a usb keyboard.
BloodRayne said:Personally I like AGP more than PCI-E...but that's just me. So I would like AGP to stay.
tazz said:I dont think APG will ever go away,
They should keep the APG AND THE PCI around to give us options.
APG is not even maxed out yet bye game makers
ThreeDee said:I'd give it one ...maybe 2 more weeks ....
Framerate said:I say whenever the AGP 8x bandwidth bottlenecks the card, which will be a long ways away.
ARN said:i would just like to say thank you. i never knew that there was any difference between ps2 and usb for a mouse and i just switched my mx700 to usb. it may just be in my head, but i think it is smoother.
It's more likely that WTX will come back to life and replace every single ATX system out there than that BTX will ever have a marketshare of over 10%. BTX is dead. No amount of hype will bring it back to life.[..] ATX will be hard to give up one when BTX becomes more common. [..]
BigIron said:>>AGP's demise has nothing to do with bandwidth. It addresses other problems and limitations<<
Really tell me more......
Ocean said:when compaq ceases to make PCs
Those have all vanished on my board, Abit IT7acascianelli said:there are other things id like to see 'vanish' before agp, like ps2, serial, parralel
omega-x said:about the usb vs PS2 mouse issue.
lets do some math.
1 mx510
1 ps2 port
and 1 usb port
the mx510 is uberaccurate
the ps/2 port can poll the mouse 200 times per second
USB is limited to 125 times per second.
has the math sunk in yet?
(small difference, i know, but i far prefer the smoothness of a mouse on PS/2 ports compared to USB)
also, PS2 is a dedicated bus. USB is shared. try gaming while you copy files off a USB2 hard drive.
BigIron said:Cool thanks for the insight Sir-Fragalot all very good points.
On an enthusiast level I think AGP will be phased out in a year or so. But on a business level, say youre the network admin for large or medium network; say 500 users and you need to do a refresh of 200 units. Lets say you push out your images and driver packages over the network, do you really want to be forced to support two different technologies requiring different images or driver packages? In a large network you want to standardize your hardware, its much easier and cost effective. So from a B2B stand point I would think AGP should be avaliable for some time to come. I am amazed how fast the industry seems to be pushing towards PCI-E though.
