Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
paint them seperately, AND make sure they are horozontal..i've tried painting case side panels while tilted, and the paint tends to run (VERY easily when tilted)unless you do a very thin coat(which takes soem time and practice, so i doubt your first paint job will have many thin ones) good luck!
