heatlesssun said:Haven't really seen any firm times on this. Some are saying as early as the begining of fall. With that in mind, I personally wouldn't get one until Vista is out, since DX10 functionality will only work with it.
So realistically, I do not think that its something to consider until then, unless the the DX10 cards are so badass that they spank DX9 cards even in DX9, I don't think that's going to be the case.
ElMoIsEviL said:Think of it this way... x1900XTX > 7800GTX 256MB SLI
So R600 > G80 > 7950 is a definite possibility...
R600 Crossfire > G80 SLI > 7950 Quad SLI.
WARDOZER9 said:the 7900 series already has DX10 capability. This was noted by PNY upon it's launch. This is why it's one of the most future proof cards right now.
I don't know if the X1900 will be 100% DX10 compatible but the 7900's will be.
Sure about that? I know they were developed to be Vista compatible but I never heard anything about DX10.WARDOZER9 said:the 7900 series already has DX10 capability. This was noted by PNY upon it's launch. This is why it's one of the most future proof cards right now.
I will not buy any DX10 cards untill there is a *good* DX10 game.
No, I waited for the 9800 and saved $200.Trimlock said:i'm sure you waited on buying the 9700 till a good dx9 came out?
Never bought one.Trimlock said:i'm sure you waited on buying the 9700 till a good dx9 came out?
Tigerblade said:So future proof they can't do AA+HDR.
XSNiper said:That doesn't make it not future proof at all...Sure the 1900 may have it, but what if it can't run DX10? So future proof it can run AA+HDR but not DX10 right?
joemama said:Sure about that? I know they were developed to be Vista compatible but I never heard anything about DX10.
who is to say the current cards cannot be retro-flashed for dx10 support? I seem to recall alot of over-engineering of the x1k ATI cards for future proofing. I am guessing that they *may* be able to play DX10 games (probubly not near the performance of the native dx10 cards tho)
Trimlock said:unified shaders is not a requirement to become DX10 compliant
XSNiper said:Sure the 1900 may have it, but what if it can't run DX10? So future proof it can run AA+HDR but not DX10 right?
travbrad said:Yeah, from my understanding it's just "prefered" by MS, but not necessary
DX9 will do almost everything DX10 can do... so who gives a frig?
lloose said:To the OP..
God pushes back dx10 cards 1 day for everytime you touch yourself...
Should I wait for DX10 cards to come out, or will DX9 last for about 4-5 years before I can afford to upgrade the system again?
