it's worthwhile to get the sataII drive, because it will probably be the same price (or cheaper). the features may not matter too much, but you dont pay extra for them, so i'd say get sataII.ohboring1 said:Ok.. that makes sense. Now, is it worthwhile to get a Sata II HD??? or would a SATA I be just as fast.
Is there a SIGNIFICANT difference between the 8MB and 16MB buffers?
They can be used to somewhat to their full potential, if and when solid state drives come out, and SAS is compatible with SATA and SAS controlers can support 127 or 128 physical devices (I don't know exactly and I don't know the theoretical maximum which is alot higher)use them in a huge array and you get alot of bandwidth to tap into.ohboring1 said:I was wondering why everyone keeps saying that SATA and SATA II can never be used to their full potential.
Lord of Shadows said:One thing I dont like about my sata drives is when I was messign with ram one day I noticed both of my sata cables werent connected. Turns out while messing with the rams the little L shapped plastic clip on both drives broke off. =/
My drives still work, cable is hanging on the pins, and are still under warranty. I wont rma them untill this summer when I have time though. (If they would even accept a rma for this reason.)
Moral of the story, sata connections arent sturdy. (3 pin fan connectors take more abuse)
And as I go on a cable connector tangent, why do laptop power connections suck so bad? Seems to be the first thing that goes on any laptop for me. (Have to play the old put the cable in the right spot trick or wiggle it till its right.)
Jonjolt said:They can be used to somewhat to their full potential, if and when solid state drives come out, and SAS is compatible with SATA and SAS controlers can support 127 or 128 physical devices (I don't know exactly and I don't know the theoretical maximum which is alot higher)use them in a huge array and you get alot of bandwidth to tap into.
