54YW4T said:i know for sure its my psu, because my freakin key board isnt working anymore. i tried another keyboard and same happened. im using the onboard keyboard
the stupid thing is, is that this happened suddenly. and there are no leaking caps!
54YW4T said:awww shit. my multimeter doesnt have a 20. it only has 10. should i get one with a 20 or it wouldnt make a difference?
Its the Electro-Tek 10729W Electrical Multi-MeterSpectre said:Can you give me the make/model of the multimeter?
54YW4T said:Its the Electro-Tek 10729W Electrical Multi-Meter
54YW4T said:when i set it to 10, its perfect. when i set it to 50, its falling apart. This is on the v12.
yes. on 50 i get like 1-3Spectre said:On 10 you get a reading of 12v? Correct?
54YW4T said:yes. on 50 i get like 1-3
54YW4T said:so what should i do know?
ok ill wait for the RMA. Im going to sleep now.....Spectre said:Well you could swap the multimeter out where you got it or just wait for your RMA. If i were you I would probably be frustrated enough to wait on the RMA.
54YW4T said:ok ill wait for the RMA. Im going to sleep now.....
jonnyGURU said:Yeah.. software is bunk. But when you see that type of fluctuation, you know something is up.![]()
