What's wrong with my L2410NM?
RedReino
Just got a Westinghouse L2410NM for a GREAT price! I'm no gamer or anything like that, i just wanted to upgrade my POS 15" CRT they gave me at work with a nice workspace...
So, i took it out and hooked up to the VGA cable and set windows to display at 1920x1200. The thing looks TERRIBLE! As if it doesn't recognize what the PC is sending out to it. When I'm looking at he OSD, it shows resolution at 1680x1200.
Any ideas? I'm stumped.
A friend of mine had the same thing happen to his last week just randomly after he had it setup as 1920x1200. If I recall correctly, it eventually just fixed itself...
"fixed itseff..."? Really? I'm not sure how long i'm going to give this thing if that's it. I'm going to take it home over the weekend and see if it looks any different on my machine at home. If not...back in the box and i'll see if i can exchange it.
I would first advise you to get a DVI to HDMI cable. The sharpness difference is like night and day. VGA is not nearly as good. Most video card manufacturers don't concentrate on ultimate analog/VGA quality any more.
Second, you may want to play with the sharpness setting in the OSD. I found at 1920x1080 everything went blurry over DVI/HDMI, so I tweaked the sharpness up a notch and the blur went away.
"fixed itseff..."? Really? ...
Yep, he said that about an hour later after that happened, it just started working again just fine. I have no idea why or what happened in the first place but he uses VGA as well.
Like 10e said, I'd recommend using DVI-HDMI. The sharpness was so much crisper and made things easier to see.
