Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Mine is showing 157 and 300 for the current values. I assume that is OK in 2D mode.
Before I had an 8800GTS (640 meg). Before I put the new card in, I ran 3DMark Vantage My GPU score with the new 5850 was more than double the old card.
However my Performance index (Win 7 Ultimate) didn't change when I reran after putting the new card in.
(still shows 5.5) I would have thought it would have scored higher.
I'm going to try the new drivers released today to see if anything changes
I never quite figured out what makes WEI tick. According to WEI, a HD 4670 is faster than a 8800GT - well, it's not. Also both a Samsung Spinpoint M6, a Spinpoint M7 (both being 2.5" drives) get 5.8, while a WD Caviar Green 3.5" also only gets 5.8 despite being a decent amount faster. Go figure
As for WEI running when it should... odd, I have to run it manually myself.
