PaperclipGod
- Dec 31, 2011
The 2130 looks like it could be a great budget chip, but its priced ridiculously: $140 at newegg, when the 2500k is just $60 more.
That price competitive with the high end AMD quad core chips (955 to 980). And yes I mean quad core. The i3 will win in most game benchmarks while the AMD quad core Phenom X4s will win when the application uses more than 3 threads.
more than 3 threads or 3 or more threads? just to be clear lol
Is there any chance of a 2130K getting released?
Probably not. Why would they release a "enthusiast" unlocked "budget" chip? They want people to buy at least the 2500k for that.
I've been running an i3 2100 in my lan machine for a few months and i'll tell you it was worth the $100 I paid for it. I came from a i5 2500k on my main machine and for the extra money I can't even tell a difference in gaming. You just dont get the fun of overclocking and all that jazz.
All in all the i3 series serves a purpose. Low budget, lower power, low heat. Honestly I had a hard time breaking 50c with the stock cooler. I idle at around 20c with water. I really would recommend the i3's over any AMD chip except maybe some of the higher then hex core chips. But if you're spending that kind of money might as well get an i5-i7. Just my 2c.
Intel's releasing graphic-less Sandy chips soon. I'd wager they cost less than their current stock as well, but how much less, idunno![]()
http://vr-zone.com/articles/intel-to-launch-graphics-less-sandy-bridge-cpus/14387.html
And if they did, the price difference between an i3 K and an i5 K would so narrow, that probably 99% of shoppers would just end up getting the i5 K, anyway.
Well since you will not be able to do Intel's quick sync thing, I'm sure they will be cheaper, otherwise no one would buy one.The new cores will just reduce their costs but I very much doubt the pricing will be different from the cores which have do not have the graphics enabled.
But I can understand why Intel is doing this. (Thanks AMD)
Intels CPU's are sweet (thanks Intel). I had to go AMD this time around, and get 4 cores for 80 bucks, really wish I had a Dual Core i3 that doesn't OC for the Game of The Year BF3.
Oh well just have to enjoy my OC'd X4, but I sure wish I would have spent more in hindsight on the i3 sense it has 2 cores and I only have 4 cores with AMD. I could be rocking minimum settings with the i3, but recommended settings with my X4 is good too! And sense I had money leftover I got a 2GB 560Ti instead of a 1GB 560Ti...really wish I had the 1GB card now also. (thanks Intel)
The 2100s are disappointing in price. It was the reason I chose an older $90 i3 540 over a $125+ i3 2100 chip. I got 4.2ghz out of the 540 at 1.34v load, which I'm sure is quicker than the 2100s at stock. Plus I also get HT and onboard graphics (though not as good as SB graphics, I don't care). If there was an unlocked SB dual with HT for around $150, I would have really considered. But nope.
You know what's also sweet? Having a job and being able to afford an Intel quad AND a 2gb video card...
No but seriously, I needed a setup that was very similar to my e3-1230 live server. I considered an AMD X4 but I wanted the setup and performance to be as similar as possible. I didn't want any surprises. Plus I only needed a dual since I only run a single VM for testing on the i3.
As far as GOTY BF3 goes, I have my 2500k for that.![]()
