Alex41290 said:if i'm correct, isn't the plain XT only PCI-Express?
{NcsO}ReichstaG said:Can't you flash the BIOS of a x800 XT to a >> XT PE?
The XT cards also mostly have 2 ns RAM - not the 1.6 ns stuff that is the cause of the whole XT PE shortage in the first place
Alex41290 said:well, i checked 'egg, and they had the XT (not PE) and it said AGP
but should we all believe newegg?
2Fresh said:The XT cards also mostly have 2 ns RAM - not the 1.6 ns stuff that is the cause of the whole XT PE shortage in the first place
{NcsO}ReichstaG said:What is the advantage of the 1.6 ns RAM?
shaihulud said:do not forget it (none pe) has 4 less pixel pipelines.
fuzzbutt99 said:So is the concensus that most XT's can't overclock to PE speeds? I've been reading alot of reviews saying that they aren't able to quite overclock to PE speeds without artifacts.
6800GTOwned said:Dell sells PCI-E x800 XTs.
mohammedtaha said:They can o/c to PE speeds but they can't o/c as well as PE
This is the reason why I am leaving this board, it is full of retarded monkeys.
