What do you thinks????? I'm just cooling my CPU and my system is overclocked its a Phenom II X3 720 with four cores running @ 3.5GHz voltage bump @ 1.456v.
Here's what I have picked...... Let me know if there is anything better.
I don't want to run three fans on high so want it to be quiet in a way. I figure the larger three fan radiator would help in that instead of the dual fan radiator.
* AquaXtreme MP-05 SP Limited Edition AMD AM2 CPU Water Block ½" High Flow fittings
* Swiftech MCP655-B™ 12 VDC Pump Without speed controller
* XSPC RX360 - Triple 120mm high performance radiator Upgraded to this radiator from the Swiftech one.
* Swiftech MCRES-Micro Rev 2 reservoir
