What X38 would you get?
its cool we're all misunderstood once in a while hehe
I do like asus too, but I've been reading about all those 'bad' striker/680i reviews I got kinda scared. Would the problems only be attributed to the Nvidia chipsets though?
Otherwise, Abit IX38 or Maximus Formula here I come :D
Maximus Formula / or MF SE
Welp, just ordered a P5E. This will replace my ol faithful P5W DH.
It was time.
But a good P35 board would still be nice for OCing a QX9650, correct? Not sure if I should go X38 or P35, since I'm not sure if SLi will be necessary for me.
Neither does SLI but they do Crossfire instead.
P35s should support QX9650s as well as X38.
In my (possibly biased) opinion few people really need multi-GPU setups.
Asus Maximus Extreme :cool:
Though I have to use a big case because its about 1" bigger than a normal ATX board
bit-tech just did a review of the Formula & Extreme today.
They din't seem too thrilled by the Formula.
So far the ASUS Maximus Formula would be my pick. I haven't worked with the abit or Gigabyte versions yet though, but the ASUS boards are tough to beat.
First i bought the Gigabyte GA-X38-DQ6, mainly because of price and that is was the first avalible and had a need of board. BIG mistake it turn out to be since i use 4GB RAM and 4x1 is the only acceptable setup around that can perform well on memory and Gigabyte missed to make 4sticks usable on this board, either i had very bad OC, only 3GHz on Q6600 G0 and only 1066Mhz on poor 5-8-8-24 timings and crappy 8GB/s read performance at tops and that on my good 1150MHz mem. When i had only 2 sticks in 3.5GHz was not stable all the time, some reboot was needed on startup to get in to windows.
No good BIOS is out either to this crap, tested a few of the brand new ones but no improwent at all from the old F5H or F3 ones.
When ASUS Maximus SE then was avalible i decised to test one out and that was THE right thing to do since 3,6GHz was a easy breeze and 1200MHz on mem at 5-5-5-12 and 10.1GB/s read on that low clock and 24/7 use, man i can se the diffrence of memoryperformance in windows and turned down memoryperformance in 3.6 on CPU to 8GB/s showes HOW slow that realy are and what good memory realy do for overall performace.
Now the heat on NB stops me since that crap out and fails Stabilitytests when hiting 60 degres celsius so anything over 3,6 is not stable under 100% load and the time of 8-12h to be considered seriously stable so i have to wc the nb as well and the fusioncrap is not good enough for me since it only gain a few degres and is poor 3/8 fitting, i use only 1/2 in my upcoming loop exept the f-fittings for memory buty that does not affect the flow or preasure at all, luckily EK has a sexy,nice specialblock for this MB just out.
3.8-3.9GHz is duable (on water of NB when use 4x1GB) with my Q6600, even 4GHz on high vcore for short use on this board and sevral GOOD BOIS has come and ZERO vdroop since loadline calibration works on quads on BIOS 505.
Only "bad" thing is the heatpipe but that is a small thing since 3:th party and aspecialy TR:s thing is always better that stockcrap or zalmancrap for that matter and TIM used are the cheapset around the planet. Even GA:s heatpipe is to small to handle the big heat put out under 100% load of Quad and OC worth the name OC and stable under the standardrate 8-12h.
I just dropped in a QX9650 and got 4.45GHz out of it.
It works a hell of a lot better than my stupid friggan 680i boards. It doesn't keel over and die on me after 1 week.
i big comfy one, i just hate foxcoon, hell just read the tom hardware review, they couldn't even give the foxconn a rating because it was not a stable product.
Doesn't Foxconn manufacture motherboards for other companies, including Intel? :eek:
yes they do, dunno about intel though, all i've ever seen imprinted on their pcb's has been intel goodness.
FOXXCON is a china based company, they are good at making small plastic covers- IE cover over your 775 mobo is a foxcon cover. But for making a reliable board... hell no
I am pretty sure that Foxconn makes all of Apple's Ipods and motherboards...
if your meaning is 'intel chipset' then they are pretty darn stable compared to other chipsets (P35 is one of the best this year has seen).
the motherboards that intel manufactures and releases themselves are pretty good too, but I haven't bought any of those boards to give any suggestions
it wasnt really meant for you to answer ;)
just trying to make a point that Foxconn actually manufacture Intel-Brand boards.
Personally I'm trying to decide between Abits IP35 PRO and Asus's MAXIMUS FORMULA. Having a hell of a time deciding though.
IP35PRO
pros:
- stable established p35 chipset and established motherboard
- about $70 cheaper
- chipset runs cooler​
cons:
- unsure about onboard sound, would probably need an aftermarket soundcard (Auzentech X-FI) which brings cost up​
MAXIMUS FORMULA
pros:
- onboard sound is higher quality
cons:
- x38 chipset is not as mature, motherboard may still have 'teething' issues
- x38 chipset apparently runs pretty hot​
This would be a board for a QX9650 so any overclocking I do would be simple cpu multiplier changes. Any thoughts?
I just bought a Maximus formula after the $50/20% off at Newegg, so I got it for around $200.
The Maximus Formula is an outstanding board. I haven't worked with the abit board, so I can't really compare the two. The Maximus Formula overclocks as well as any P35 board and I had zero issues with my review board. The board I used was a retail sample as I recall.
Regular or SE version?
MAXIMUS FORMULA
pros:
-PCIe 2.0 Support
cons:
Fixed...
Just a thought concerning maturity statements about Intel chipsets. Basically Intel chipsets are good to go from day one. Though there are some issues, they are extremely rare. I'd take Intel drivers on release day over NVIDIA drivers that are six months old.
BTW I've even used alpha Intel chipset drivers that were running on early hardware and I didn't even have any problems with that setup either.
cons:
You should add another con to the abit board: gimped throughput on the onboard LAN controllers since it is PCI based, but this may be minor to you.
I'd go for the ASUS board. :p
cons:
MAXIMUS FORMULA
pros:
You reckon?
I think that if you feel the need for an X-Fi on the IP35 Pro then you'll feel the same need on the Asus.
Imo it all swings on whether you need the 2nd X16 (electrically as well as physically) PCI-E slot as performance otherwise is similar.
The minor throughput hit is only of potential concern to people who regularly do very large transfers over a gigabit network with performance RAID arrays (e.g. RAID 0) on both sending & receiving systems - to the other 99.9% of people it's just not a concern as it's still faster than a single HDD (even a Raptor) can handle & 10s of times faster than domestic broadband.
cons:
Most onboard sound is pretty close. If you feel the need to upgrade the sound on one board you'd probably have to do the same thing on both of them.
I've done a number of network benchmarks on integrated NICs. The PCI and PCIe onboard NICs all pretty much suck. Especially when compared to some add-in boards. In my opinion the only onboard solutions that are worth a damn are the Intel ones, but Intel hasn't done any for awhile. They all now have a Broadcomm, Realtek or Marvell PHY and that just plain sucks. The CPU usage is generally high and the performance poor. The difference between PCIe and PCI in this regard is minimal at best.
Actually, oddly enough Intel has chosen to reintroduce an integrated NIC into their ICH9/9R, but most of the motherboard makers have chosen to stick with others. Intel must be charging quite a mint for their PHY if it's cheaper for the motherboard makers to buy both a Realtek (for example) chip and PHY rather than just the PHY of Intel. The two exceptions for P35 boards are ECS and, naturally, Intel's own board. I'm sure that Intel's own X38 motherboard, Bone Trail, will use it too when it comes out.
That said, though I could see it mattering for networking between multiple computers at the same location, having a crappy NIC doesn't really affect you if you have residential broadband, right?
I guess I need to check up on my ICH9R specs. I don't remember it including any networking solution. On the other hand, you are correct, the crappy NIC doesn't matter with any of the broad band solutions that most all of us can afford to have in our homes. The only time it is of consequence is when you are transfering large files between two machines. Even then your Gigabit hubs and switches are going to add some overhead slowing things down further even if your NICs didn't. There is always a bottleneck somewhere.
Here are the specs for the P35 and the X38 (albeit it's a bit redundant, as they share the same Southbridge). And it's not just the ICH9R; it's the whole ICH9 family. And I completely understand you not remembering that; motherboard makers certainly aren't taking advantage of it. :p
I haven't seen an integrated Intel NIC in so long, I just figured they hadn't bothered including one in the ICH9x.
ASUS MAXIMUS FORMULA SE version discontinued. I just called to place an order.
It is no more. Anyone know why?
Where did you place the order? Sometimes a retailer, or e-tail shop will tell you that it is discontinued when in reality, it is the store that is discontinuing carry the product. That seems to confuse many retail employees.
I always here about all the Republic of Gamers motherboards always being discontinued after a run of only four weeks or so. Still the first two, the Crosshair and Striker Extreme are still available to this day. Though the ASUS Commando was short lived as it was replaced by the Blitz Formula, Blitz Formula SE and Blitz Extreme.
I was going to buy the Asus Maximus Formula SE, but like I said. I can't now.
I guess I'll just get the ASUS MAXIMUS FORMULA.. oh well...
Even if the Maximus Formula SE is discontinued, the regular Formula should have everything the SE had minus the Fusion block.
