What would you do?
Pegesus
Ok here's my dilema....
I'm building a gaming pc. I'm fabricating my own case for it as well. Here are my intended parts to go in it...
AMD FX60
eVGA MicroATX MB
Dual eVGA 7950 512mb
WD Raptor 150gig 10,000 RPM
Pioneer DVD RW
X-Fi Fatal1ty Pro
Corsair XMS 1gig x4
Silverstone 750w PSU
In addition i have 4 80mm fans and 1 120mm fan, I am deciding between the Zalman CNPS9500 CPU cooler or the Fatal1ty i have both of them if i use the Zalman i'll be able to use the 4 1 gig sticks. If i go with the Fatal1ty i'll only be able to get 2 sticks in there thus buying 2 2gig sticks.
Now onto the problem. Since its a microATX I cannot fit the Fatal1ty VGA coolers and my X-Fi soundcard. So if you were in my position would you either:
A. Ditch the soundcard and go with onboard
or
B. Use the stock VGA coolers and keep the soundcard
If you're making your own case, why are you going with microATX? A full sized ATX board would give you a lot more room and would probably have better cooling suited for gaming.
Unless you physically can't use an ATX board. =/
Well what matters most to you? Quality sound or a cooler system?
Personally, I'd ditch the VGA coolers and see what happens. When the system is together, see if the temps for the graphics cards are high. If not, keep the X-Fi. If it is high, go with the VGA coolers. Simple as that.
Easier said than done....
Since i'm making my own case i'm cutting out the PCI slots for the specific parts i'm putting in. I don't want to just put it in now and possibly take it out later and have a large slot exposed.
I guess what i really am wondering is if the eVGA cards come with a good enough cooling fan on them.
But then on the flipside the added X-Fi is going to reduce airflow to that video card and increase system temp alone from being active.
Hmmmm...anyone else happy with their onboard AC97
