TangledThornz
- Jun 12, 2018
TNT2. Good enough for AVP 1999 which is the reason I bought my first PC at almost $2,000!!
I had a PCI Voodoo Banshee and it died early due to no heatsink and poor case airflow. Replaced it with some SiS abomination (6326 IIRC) which was used up until a friend gave me his old Voodoo 3.GPU's with no fan support was hip back in the day. I think the G200 was the hottest GPU i've ever had.
But yeah, depending on what you count, it was either the built-in RAGE LT PRO, or a plain old PCI Radeon card used as an upgrade path on a machine that had neither AGP nor PCI-E.
To be fair that Cirrus Logic card wasn't bad, but it was beholden to the CPU in that machine for Quake. The 5x86 was a solid high-clocked 486, but even at 160 MHz with a 3Dfx Voodoo board it would have been hard pressed to deliver a reliably good experience.The Cirrus-Logic 1MB SVGA card that came inside the assembled AMD 5x86-based system I bought from a local Vietnamese computer dealership in the suburbs of Boston (later shut-down because they use to pirate all the MS-DOS/Windows 3.1 installations that came on their machines). It was so powerful it could play Quake 1 (which had just been released) at 10 FPS at 320 X 200.
Edited: OKay, I just realized that the Cirrus-Logic wasn't a 3D accelerator card so the first one I owned that was was the Stealth II with the Rendition Verite 2100 chipset. It played the special edition version of Quake designed for that chipset at +25 FPS, I think. Surprisingly it had full screen anti-aliasing at that framerate when even the Voodoo couldn't do that (?)
The v2100 was a decent chip, and VQuake was the best of all worlds in terms of running Quake in 1997. 16-bit color, edge antialiasing, SVGA resolutions, and accurate reproduction of software rendering features like overbrighting for lights made it a cut above GLQuake for everything but raw performance on faster hardware. I wish like hell Rendition had stuck around.
think this was mine too. just happened to be in a computer i ended up withGeforce 2 MX 400
