what video card would give me at LEAST a 25% boost in FPS over my 1070 ?
Discussion in 'Video Cards' started by troyquigley, May 17, 2018.
  1. troyquigley
    troyquigley Limp Gawd
    465
    Jul 13, 2005
  2. AltTabbins
    AltTabbins Muh Feelz Got [H]urt Right in the Pussy
    18,146
    Jul 29, 2005
    1080ti, Titan.
    That’s assuming the rest of your computer isn’t holding back the 1070 already. Also depends on your games resolution and what games you are playing.
  3. HiryuuX
    HiryuuX Limp Gawd
    206
    Jul 16, 2017
    Basically that, only the 1080 Ti and Titan XP/Z would give you that much of a boost in today's market.
    I would personally suggest holding off until Nvidia provides concrete information on the next-generation GPUs though.
  4. troyquigley
    465
    Jul 13, 2005
    sorry. forgot
    2560x1440
    i5-6600k @ 5ghz
    ram ddr4 @ 3200 16gb
  5. Shadowed
    Shadowed Limp Gawd
    384
    Mar 21, 2018
    1080 ti or bust. But if you are at 60hz, I wouldn't bother.
    tungt88 likes this.
  6. Guarana [BAWLS]
    Guarana [BAWLS] I am THAT Stupid
    1,704
    Oct 3, 2001
    Are you Freesync or 60Hz?
    With that rig, I imagine the 1070's pushing FPS just fine for now. (Might be worth waiting for the next gen.)
    tungt88 likes this.
  7. AltTabbins
    18,146
    Jul 29, 2005
    Looks good. A 1080ti would be the next step up. Should be about 25% faster if not a little more.
  8. troyquigley
    465
    Jul 13, 2005
    looks like I need to wait for the 1170
  9. Shadowed
    Shadowed Limp Gawd
    384
    Mar 21, 2018
    That will basically perform like a 1080 ti.
  10. thebufenator
    thebufenator [H]ard|Gawd
    1,040
    Dec 8, 2004
    Consider that you only have 4 threads, and some games are pushing more threads now.
    Simmonz and defaultluser like this.
  11. defaultluser
    defaultluser I B Smart
    11,949
    Jan 14, 2006
    Yeah, if you're looking for more than 60fps, you should consider a CPU and GPU upgrade.
    You can reuse your DDR4, so your only cost would be a motherboard and CPU.
    Use this review to see how much your performance could be CPU-limited. Compare your i5 6600k to i5 7600k:
    https://www.techpowerup.com/reviews/AMD/Ryzen_7_2700X/12.html
    If you're still seeing slowdowns when you crank down a few settings, then you're probably CPU-limited.
    EDIT: overclocked should be just fine then.
  12. doubletake
    doubletake Gawd
    513
    Apr 27, 2013
    It's more like 40-50% faster in practically every single game when running at 1440p and UHD. Only a few games that that are more cpu-heavy and are run at lower resolutions will bring that gap down to about 30%.
  13. NKD
    NKD [H]ardness Supreme
    7,128
    Aug 26, 2007
    I was stubborn at first thinking my i6 7600k overclocked to 4.9 wouldn't hold me back and I have been researching at 4k it actually does compared to 8700k on a 1080ti, especailly with minimum frames that should help with overall smoothness. I still wasn't going to upgrade but some how my job still qualifies for intel retail edge and I totally forgot about the summer deal. I got it in time and got the 8700k for 219 lol. It was hard for me to not do it. Only reason I would be ugprading to 8700k because after upgrading selling my 7600k and mobo would only cost me little money. However I will be getting a little better AIO water cooler since I have 140mm AIO water cooler, probably not going to cut it for me.
    For me it was no brainer. I don't expect much increase but I did it for overall smoothness of game play rather than more frame and to get better minimum frames. I have noticed 8700k is pretty damn good at that.
    Maddness and AlphaQup like this.
  14. AlphaQup
    AlphaQup Limp Gawd
    229
    Oct 27, 2014
    Just made a similar upgrade myself, 4690k @ 4.6GHz to an 7700k @ 4.8GHz and got pretty much nothing worth noting on the maximum (maybe 5-10 or so), but minimums jumped through the roof (easily 30+ in PUBG) and mid's were slightly better too. The smoothness increase was DEFINITELY noticible.
    Maddness likes this.
  15. Shadowed
    Shadowed Limp Gawd
    384
    Mar 21, 2018
    Going from a 4690k to 5775c OC really helped me at 180hz.
    AlphaQup likes this.
