Need use-case context here, OP. Check out crimsonyoshi's post up above kirbyjr's.
That being said, here's the AMD side:
If you stretch your budget just a little bit more, you could score HD7770s all day long for ~$60-70.
No-Exceed $60 option: HD7750s, even 2GB ones.
7750s and 7770s will do you quite nicely as a 2-way work/play option. Not up on the NVidia stuff, so perhaps we could get someone to post options there.
Edit: 7750 = R7 260, 7770 = R7 260X
@Kirby's query - The GTX570s are about $100 and up. AMD's option @ $100 used is the 7850, and it's surprisingly close to the 570 for performance.
