What upgrade path to take?
smesx
General browsing, gaming, hd video encoding off the DVR... Parts that are switched out will go towards an HTPC
raised from $500 to $800
3) Where do you live?
Indiana
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
That is the question.... I am thinking CPU/MB/RAM is the next upgrade but wanted others opinions.
I like my Lian Li V350, MB's would have to be mATX, will reuse SSD, HD's, optical, 5870 and possible the PSU, already have a mATX case for HTPC
6) Will you be overclocking?
yes some, nothing too extreme though, i'm no longer using my custom watercooling
2x24" HP LP2465 + 1x24" HP LP2475w. Eyefinity kicks ass! :D
Not pressing, doing research now on the next upgrade... within 2-3 months though.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
raid, firewire, eSATA, mATX, preferably good cooling on NB/SB already, USB3.0 and SATA 6Gb/s wouldn't be bad either
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? 32bit or 64bit?
Student W7 pro x64
I've been looking at putting together a HTPC capable of 1080p x264 playback. Rather than build something new for that I'd like to upgrade my main box and reuse my current mb/cpu/ram + my old HD4850 for the HTPC.
I feel like I've been following a pretty good upgrade path having replaced my 4850 with a 5870 and my raptor with a X25-M g2 before upgrading cpu/mb/ram. I'm actually fairly pleased with the performance on my current setup except for encoding time. I've really been going back and forth on if I should spend less money on an HTPC setup, or more money on future proofing my main box and doing a hand-me-down HTPC. Then I run into the cost/benifit of i7(more than $500) vs Phenom II X4 for encoding.
I'd be curious to know what type of percent decrease in time i7 or PII X4 would do for x264 encoding vs my E8500 @ 3.8GHz.
You can see the performance difference with Core i5, Core i7, AMD Athlon, and AMD Phenom CPUs, in video encoding with these reviews:
http://hardocp.com/article/2009/09/07/intel_lynnfield_core_i5_i7_processors/4
http://www.xbitlabs.com/articles/cpu/display/core-i7-870_10.html#sect0
http://www.bit-tech.net/hardware/cpus/2010/01/04/intel-core-i5-661-core-i3-530-cpu-review/6
Though I would not recommend reusing that PSU. So with that in mind, an AMD Phenom or Core i5 750 build would be your best bet. I recommend this replacement PSU:
$100 - Corsair 650TX 650W PSU
If you replaced your mobo/cpu/ram, would you get a regular case, or stick with the V350? 'cuz I was gonna say move everything except the HD5870 and X25-M to the HTPC, and grab a new mobo/cpu/ram/case/psu for your main system that you'd be using for encoding, then a new hdd (F3 500GB) and cheap vidcard (HD 4550 or better) for your htpc.
@Danny Bui
Thanks for the links. Didnt realize how much intel owns amd for encoding/transcoding. Also, I suppose I would need an extra PSU for the HTPC so I could upgrade that too, wasnt thinking about that in the total cost though so that sucks.
@enginurd
I'd like to keep the V350 for my main rig. I have a spare mATX case for my HTPC. Was going to put my HD4850 I have laying around in the HTPC. Also already have a HD that I could use for the HTPC, an old raptor, all media comes of a WHS box so space isnt an issue. But good point on the F3, I have a 1TB and its faster than the old 74GB raptor. Great HDD.
@Danny Bui
You can use the OCZ PSU in the HTPC but not the new PC upgrades.
Ok. So I did some soul searching (and money searching) over the weekend. Listed several things on ebay to sell and am highly considering bumping my price up to the $800 range.
What I am looking at so far.
89.99 Antec TruePower New TP-750 750W Just dropped the price today by an extra $30
209.99 ASUS Rampage II GENE LGA 1366 Intel X58 Micro ATX Intel Motherboard
54.99 Noctua NH-U9B SE2 92mm SSO CPU Cooler One of only a few coolers that will fit well into my V350 case
433.98 Intel Core i7 920 + OCZ Gold 3x2GB DDR3 Combo [+$20 mail in rebate]
Add in about $10 for shipping an that comes out to $799.58. So i have 42 cents to spend.....
I lean towards the 1366 because it seems like a more future minded platform. I also figured since I jumped in the high end for the SSD and the 5870 I may as well jump in for the CPU. Thoughts???
Looks good to me. That PSU price is a sales price BTW so you might want to buy the PSU ASAP.
Posted via [H] Mobile Device
Amz has the tp-750 blue for the same price, for my fellow cali peepz. ;) ... and if any of you would like to spot me for one, i'd greatly appreciate it (just threw down cash for another ssd, lol, otherwise, i'd be grabbin a couple of these, hehe :p).
