What to do...?
BugginOuT
I have a dilemma. Would it be wise of me to use my existing rig (check sig) for virtualization and get a new system for my gaming, day-to-day tasks or part out my existing rig and get a new system that can handle both virtualization and games?
Gaming (BF3), Virtualization, Web Browsing, etc...
<$1500, but, lower be the better
NJ
CPU, RAM, Graphic Card, PS, HSF (H80 or H100), Optical Drive (BluRay player and/or DVD-Burner)
Corsair 600T se. I might go with an Corsair AX750, because I want the fully modular route.
6) Will you be overclocking?
Mild O/C
24in Dell - 1920x1200
Probably in a few weeks
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? etc.
RAID, SATA 6Gb/s
Windows 7 Pro 64bit
Let me know if you need additional information.
Reuse that PC for virtualization and get a new PC for gaming if you're really serious about doing virtualization work. If virtualization is just a hobby, just get a new system that can handle both virtualization and games.
However, I'd recommend waiting until Ivy Bridge hits and then getting a new PC then.
If you're going to be doing virtualization while playing games, then build a new system. Otherwise, you can save yourself some cash. Of course it's generally better to have separate systems than not, but it is of course much more expensive.
Could you give more info about what virtualization needs you have?
Going to build a small virtual test lab at home, probably going to put up a DC, DNS, Exchange servers on ESXi. Just to familiarize my way around ESXi and freshen up my skills on the MS portion.
As Danny said, think i'm going to hold out on IB. I got myself confused with SB-E vs IB, thought IB was already out.
Right now, I'm leaning towards parting out my existing system and build a new one. I don't have alot of real estate on my desk and would probably lighten my electric bill.
I'll resurface this thread when IB hits the market. Thanks for the help.
