So I've been having some issues with my mobo and hd5870, and I'm not sure if it's the vcard or the motherboard, or the combination of the two. I had none of these issues with my 8800gt a couple years back (same cpu/mobo).
The problems I'm having are related to the graphics card driver not responding (typically after waking from sleep). I originally thought is had to do with my motherboard bios not supporting some feature that win64 required (can't remember what it was), but I switched to 32bit recently to see if the problem disappeared and it didn't help.
At this point I'm considering a couple different options:
1) ditch the hd5870 for the 8800gt to see if it helps, if so get a gtx460 or something
2) rma hd5870?
3) assume it's the gpu/mobo combo and get a newer mobo (wouldn't need anything else like memory, heatsink, cpu)
4) go for it and get an i5-760 or something (expensive though since I'd need cpu/mobo/ram)
5)?
What do you guys think? I almost don't want to upgrade everything since it seems like the 1156 socket will be obsolete soon, and the q6600 is still pretty capable, but I need this computer to work reliably....
2) rma hd5870?
5)?
