What to do with connections on differing products?
Parker
I have a Silverstone SG01-BW case and using a Gigabyte GA-G31M-S2L motherboard. The problem I run into is connecting the front ports (audio, usb, etc) to the motherboard. The computer case instructions don't have anything on it but the motherboard does. However, the motherboard instructions have different labels than what the case connections do. So how do you determine where the connections go correctly.
Just look at the motherboard itself. Most modern motherboards these days list the which pins are the PWR or power button and which are the HDD LEDs, RESET, etc.
