I only really go out of my way to disable three things:
1) UAC
2) Hard Drive Indexing ("Windows Search" in services)
3) System Restore (If I really bork my box, I'll just do a format)
So i just installed Vista Ultimate 64bit for the first time, i know that it comes with a lot of services like protection here and there, firewall,etc.
What should i disable/enable to make it perform better?
Leave it alone.
Disabling and "tweaking" shit will in the long run make shit worse. . .
I would not install games on C because the size of a modern game is more than the entire operating system. It makes it a pain to do OS backups and virus/malware scans, where as the games can be reinstalled very easily. My Vista partition is 25GB and I have 150Gb partition for games. If I keep games installed on a seperate partition, most of them wont need to be reinstalled after a reformat/restore or in a dual boot situation. I have left UAC on because it doesn't bother me, but I'd mutch rather turn it off instead of filling a large OS partition.
I turn off UAC, System Restore and windows firewall. The three of them are all mediocre (your account is a "limited admin" so if anything that is really determined to install itself on vista every wanted to (read: virus) UAC is NOT going to stop it.. worst it can do is say: oh shit we've got a problem..
Windows firewall doesn't block jack shit for incoming problems. Install Comodo Firewall Pro and be done with both firewall and antivirus problems.
System restore.. If you're not backing your shit up.. Chances are system restore aint gonna help you.
Disabling UAC, System Restore, the Security Center, and the Firewall isnt going to make anything worse. If you are a member of this forum, you shouldn't need any of those on anyway. They are just annoyances. Of course I would NEVER suggest any of that to a casual computer user. In fact, I make sure all of that is on on my parents/siblings computers at all times.
Cat:
There's a reason that TGTC guide is as detailed and thorough as it is... <hint, hint>
ROFLMAO. You are being sarcastic, right?
1) UAC
Why would you want to confine your Vista install to a small partition? There's nothing wrong with keeping games on the C partition. Backing up to a server/external drive is still as easy, and with the cost of hard drives these days, no one is using tiny drives anymore. There's also very very little reason to dual boot anymore, so that "advantage" goes out the window as well. If a game is too old to run in Vista, it can easily be run on an XP VM. StarCraft works great like this, for example.I would not install games on C because the size of a modern game is more than the entire operating system. It makes it a pain to do OS backups and virus/malware scans, where as the games can be reinstalled very easily. My Vista partition is 25GB and I have 150Gb partition for games.
I believe, in turn, you've also disabled ReadyBoot, which speeds up the boot process. If this is the case, I'd re-enable the ReadyBoost service. If you aren't using a ReadyBoost configured flash drive, formatted to be used for ReadyBoost, the service isn't really in use.The only thing I've disabled was Readyboost. Given the amount of RAM I have, there was no reason for it scan and test each flash drive I inserted when I wouldn't use them for Readyboost anyway.
The people who reccomend turning off UAC are being retarded. If its really bothering you, turn it off while you install everything and then turn it back on. UAC is a huge security feature and the only line of defense against zero-day exploits.
It's not always "retarded".
There are other reasons that I find it annoying and inconvenient. As I travel to clients networks, and need to do work on programming switches or routers....I very frequently have to go in and modify my network properties, often just assigning static IP addresses. This on a laptop that I don't do much but network chores and remote desktop on. No gaming, not much surfing.
