Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Microsoft Windows..........................
Am I missing something here?
Anyways, all you have to do is make sure the input is not muted in the windows volume panel, and that the volume is at a resonable level. Then just start sending the music into the input (like, if its a CD player, push play, if its a mic, start talking, if its a radio, make sure its on).
I personally have my little radio connected to my sound cards input. When I want to listen to it, I turn it on and unmute the line input. ^_^
lol yeah, I realized that was all you had to do little bit after posting this, I just figured you would need some software running in order to play it, did not know it would just play once its plugged in.
