What size hole saws do i need?
wordomouf123
I need holesaws for an 80mm and 120mm fans for a case i am going to be building soon, what re the sizes plz? thanks!
Convert to inches by dividing by 25.4 and round down. 3" for 80mm, 3.5" for 92mm, 4.5" to 4.6" for 120mm
Im not sure about the 80mm fan holes, but the 120mm are easy. Just trace a circle around a CD onto what you want to cut. It makes the exact size(or close to it) needed for the 120mm fan.
You can use a CD for a 120mm, but I'd leave about a quarter to half a cm all around or you may end up with a hole just a little too big.
for the 80mm fans use the 76mm or whatever saw... the 120 i think was like 112mm or something to that effect
did you guys know that good does all of that?
like if you wrote in the search box...
"80 millimeters in inches" it will give you the conversion.
