wake6830 said:If I keep the OS by itself, that partition won't become fragmented like it would on a normal drive where i'm storing and deleting downloads and installing/uninstalling software. right?
Incorrect, this is why I asked in the first place. People have misconceptions about partitioning, this is one.wake6830 said:If I keep the OS by itself, that partition won't become fragmented like it would on a normal drive where i'm storing and deleting downloads and installing/uninstalling software. right?
How does having them on a seperate partition protect the data? If the drive fails, you lose all partitions. If the OS fails, you don't lose data. They are mutually exclusive.abudhu said:Well I have an entire HD that just has the OS installed on it. All programs and files I store on my other. The only thing this accomplishes is that 1) if the OS Fails, my info isnt lost...
Phoenix86 said:How does having them on a seperate partition protect the data? If the drive fails, you lose all partitions. If the OS fails, you don't lose data. They are mutually exclusive.
wake6830 said:I'm doing a reformat & reinstall of XP Home, and I want to put the OS on its own partition. I have one 80gb WD hard drive, and a 250gb Maxtor.
What size should I make the XP partition?
Ahh, the OP is talking a different scenario... He *is* talking 1 drive 2 partitions.abudhu said:Huh?
2 HD's....
Its not 1 HD with 2 Partitons...
Its 2 HD's with 1 Partiton...well..the first one has 2, cause on Linux and windows
Phoenix86 said:Ahh, the OP is talking a different scenario... He *is* talking 1 drive 2 partitions.
Phoenix86 said:Partitioning just waste space (ex. "room to breath") for the drive the OS is on.
wake6830 said:How about this?
80gb drive partitioned with 20 for the OS, 30 for apps and 30 for music, movies, pics.
250gb drive partitioned with whatever's necessary to make a backup image of the 80gb drive(s) and leave the rest for my pvr recordings (hopefully at least 200gb).
Phoenix86 said:I can see keeping the OS+programs seperate from user data (documents, music, movies, pr0n). However if you seperate programs from the OS, and the OS crashes you still have to reinstall the programs, so what's the point?
If you do seperate data from OS+progs how much space do you assign for the OS+progs.? When you combine these two your size requirements are completely unknown based on not only what your installing today, but future apps which can vary a LOT.
So even that has problems.
For those of you partitioning how do you seperate your data?
djnes said:If your going to do that, make it a 50 GB for the OS and apps. I have always felt they should be installed on the same partition. Apps should be installed to C:\Program Files, and no where else.
TwiztedFait said:*shrug*
you would get better performance if they were installed on a different drive.
But to each his own
Phoenix86 said:For those of you partitioning how do you seperate your data?
djnes said:No, you wouldn't....these are applications we are talking about. It you have nothing correct to contribute, please don't.
No, it doesn't make sense to me. OS+app requirements vary a LOT from machine to machine, *and* over time. If you guess wrong (small), you can face reformatting the drive anyways. If you guess large, your not allowing the space to be used as effeciently as possible. A single partition solution will only run out of drive space when the drive is full, a partition will run out of space when the partition is full, but there is more space on the drive.Mauli said:well, as i said before, i have a 20 gig partition for all prgrams that need to be reinstalled when windows is reinstalled. That way,yes i will have to reinstall them, but i wont have to go through my other partions tryign to find all of them. makes sense?
You know you can ask for a refund.pbj75 said:Do you realize you sound like a complete ass? Same thing on your earlier post.
Cute, and your calling him an ass? Pot, meet kettle.BTW, you spelled "if" incorrectly in your first post.
He said "should" not "have to" and "I have always felt" not "you should never do." Since he's giving his *opinion* he is absolutely correct. You cannot have an incorrect opinion, only an incorrect fact. Please if you want to contribute, do so. If not STFU and quit trolling.While there are certainly many valid reasons to install apps in "Program Files", there are many equally valid reasons not to. Your statement is NOT correct.
abudhu said:I can say, that the way you are all going youd be appalled and shocked to here that I don't even partition my drives!
djnes said:Interesting....then how are you able to write data to them???
The point you missed above earlier is some people can't take sarcasm or comments directed at them. Quite a few people on here are wound so tight and are so full of themselves they can't possible allow anyone to have a differing opinion or to be corrected, when they are wrong. Such is life I guess, but those people are the ones who get fired from job after job. They need to just lighten up.
djnes said:Do you realize sarcasm is too advanced for you? I think Phoenix86's comments shut you down well enough that I don't need to add anything. Oh, except this. There aren't any valid reasons to NOT install apps in Program Files. There's no reason to put them anywhere else. Common sense, logic, and good computing habits say that's where they should go.
pbj75 said:It is not a black and white design decision. Segregating different types of data based on access patterns has been around for years. Windows XP itself automatically moves frequently used files on the hard disk to minimize access time. If you are using an application that generates large temp files (e.g. Premiere, MathCad), you don't want those big files to be mixed around with your OS. It causes unnecessary work for Windows since it is constantly cleaning crap up.
Disregarding the start of your quote, there are many valid reasons to not install apps in Program Files. How about two quick examples.
There are numerous legacy custom apps that run fine under XP, but can't handle having a space in their path name, e.g. "c:\Program Files\legacy.exe". For those apps, they cannot be under Program Files.
By keeping the Applications in a separate partition, you can minimize the size of your Windows partition, enabling a full OS backup to fit on one DVD and making an OS backup/restore less painful. If you are someone who is constantly tweaking Windows, that can make life much easier.
pbj75 said:r00k
What about your swap file? Do manage it or do you let XP have its way?
