- Jun 12, 2004
Looking at the fan on the back of this case (Rosewill RA-HG-M-01), is that 40mm? 80mm?
TIA!
TIA!
Looks like 120mm..
If I end up ordering this case for my gf, I'd like to be able to replace its fans with silenx 80mms.
new egg says its 120 mm fan..its not back fan is a 90mm fan and the front/side panel will take an 80mm.
back also has holes to replace 90mm fan with an 80.
SilenX fans are garbage. They are overpriced, unreliable and resonate badly even with silicone mounts.
Check out SPCR for good fans. The current favorites are the Nexus Basic fans (80mm, 92mm, 120mm) which are rebranded Yate Loons ($5 at Petra's), but apparently cherry-picked, for static pressure applications (heatsinks, radiators) and Scythe Slip Streams (120mm) for exhaust where static pressure is not necessary. SPCR also reviewed the SilenX fans and found that their airflow-to-noise ratio was very good (better than the Nexus) but its tendency to resonate due to the metal frame made for a much more annoying sound signature. And the difference was very minimal.
Sweet, I'll check them out. I've used a 120mm silenx fan with my Scythe Katana 1 HSF with wonderful results. But if you insist I can get the same for less, then I'll take your word for it.![]()
