Better gaming, video encoding, and all around performance. It sometimes feels sluggish, and firefox takes years to load. I'm on top of maintenece so that's not the issue. I'm using a samsung 2253bw @ 1680x1050. Psu is a antec 430w. I'm running xp 32bit(if that matters)
I checked the ecs site and it only showed 1 ecs amd 690g mobo. I checked the cpu support and nothing new was supported. The fastest cpu supported was the x2 6400 or x2 6000.
With that res the 9600gt is probably being pushed past its best. But, that all depends on what games you play.
i play fallout 3, world @ war, and nfs most wanted
forgot to add that my videocard is so long that it blocks 2 sata ports since the layout on the mobo is terrible...
selling is gonna be almost impossible
is the video card that bad? i remember paying 200 for it and giggling like a little girl when the ups guy got here lol...then again that was back in april of 2008..
I'll take the 9600GT off your hands for $30 shipped![]()
J/k!
The 9600GT is ok but it's simply not that capable of high settings with games on a 22" monitor. Luckily for you. COD: WAW is heavily GPU limited so if you were to upgrade to the HD4850, you'd be fine with that game. However FO3 and NFS:MW are heavily CPU limited so there will a major bottleneck as tiraides said. So the CPU and mobo upgrade is probably your best bet
If you haven't already, reinstall your OS onto the WD 640GB drive you have. It's significantly faster and more snappier than that old 120GB HDD.
even if i won't be overclocking for a while?
